Endyn Breather and Turbo Specs
Old Aug 20, 2005 | 05:13 AM
Dunc's Avatar
BCICAN
Default Endyn Breather and Turbo Specs
Has anyone installed an Endyn Breather kit on an LS/VTEC...is it possible? Have pictures?
Also, do you know the torque specs for the bolts that on the turbo housing...both on the exhaust and on the compressor? I am talking about the bolts that hold the plates to prevent the turbo from just spinning around. Thanks.
Old Aug 20, 2005 | 05:23 AM
B20TDC2's Avatar
Default Re: Endyn Breather and Turbo Specs (Dunc)
breather kit works the same on ls vtec, i have it on my b20 vtec
Old Aug 20, 2005 | 05:34 AM
Dunc's Avatar
BCICAN
Default Re: Endyn Breather and Turbo Specs (B20TDC2)
thats what I thought....because the B18B block has the pcv valve (the little black box by the oil filter) correct?
Modified by Dunc at 10:53 AM 8/20/2005
Old Aug 20, 2005 | 06:31 AM
Rod.'s Avatar
yes, some reason my 96 block didnt have it
Old Aug 20, 2005 | 06:54 AM
Dunc's Avatar
BCICAN
Default Re: Endyn Breather and Turbo Specs (Rod.)
mine is a 97.....guess we'll cross that bridge when we get to it later today. Thanks guys so far
jamal-188
Jul 6, 2002 06:24 PM
Teg4e
Jun 26, 2002 09:07 PM
Seraph0
Jun 5, 2002 09:31 AM
