PUTTING ON H AND R'S
Old Aug 20, 2005 | 03:48 AM
yellowjdmcrx's Avatar
Default PUTTING ON H AND R'S
GUYS GUYS GUYS, I BOUGHT SOME H&R'S FOR MY CAR FINALY AND WANT TO PUT THEM ON,I DONT HAVE MUCH TOOLS RIGHT NOW SO I am wondering if anyone can tell me what all is needed to do the spring cvhange,i gots the race springs,i was told it isnt **** to do it,i have changed springs before but i used a spring compressor at the shop i used to work at. well any help will be greatly appreciated
thanks
me
Old Aug 20, 2005 | 11:04 AM
Default Re: PUTTING ON H AND R'S (yellowjdmcrx)
bump please
Old Aug 20, 2005 | 01:46 PM
JesseCRX's Avatar
A pair of spring compressors.
The right size metric tools to take off the top mounts and the lower fork.
It helps to have a friend help you out too.
Secure the car on jackstands.
It helps ALOT to have an impact gun to make it easy.
Sometimes getting the top nuts off the shock stem is a BITCH because it can get stuck and just keep spinning with the shock stem. This is where an impact comes in handy.
Old Aug 20, 2005 | 08:09 PM
Default Re: PUTTING ON H AND R'S (JesseCRX)
thanks. i am gona have to have friend help me b/c i dont have a compressor or an impact
Old Aug 20, 2005 | 08:14 PM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowjdmcrx &raquo;</TD></TR><TR><TD CLASS="quote">thanks. i am gona have to have friend help me b/c i dont have a compressor or an impact</TD></TR></TABLE>
good luck
Old Aug 21, 2005 | 08:41 AM
Default Re: PUTTING ON H AND R'S (88 Crx Si)
anymore help would be greatly appreciated
Old Aug 21, 2005 | 08:49 AM
EFHbSi's Avatar
in the frount take out the 17 and 14 mm bolts take the hourse shoe thing out and take the break lines off the strutt(i cant spell) i think they are 12mm then when the break lines are out of the way you need a alen and i 14(i think) mm box end wrench and hold the alen and lossen the bolt the stock spring will shoot down. and then but it back to geather. just a tip do not use the dust gard in the back and dont to for get to cut the bump stops(leave 1/4 in) good luck. sorry i cant spell ...
Old Aug 21, 2005 | 07:01 PM
Default Re: (EFHbSi)
thanks man, the dirrections say to cut the bumpstops if u want to lower it another .5 in,which i will do
ej8coupegsr
Nov 19, 2009 04:33 PM
WHiTETYPEs
Suspension & Brakes
20
Feb 4, 2005 10:26 PM
Kirei
Oct 5, 2003 08:30 PM
Chip398193
18
Jul 8, 2003 04:57 AM
tjtruong
Nov 27, 2001 09:30 PM
