Which CEL's cause LIMP / SAFE Mode ?
Old Aug 19, 2005 | 07:55 PM
P95's Avatar
P95
Default Which CEL's cause LIMP / SAFE Mode ?
is there a chart or list that can explain which CEL codes will cause the car to go into limp mode?
I have code 45, but it doesnt seem to be affecting the performance any.
isnt the ecu supposed to go into safe mode?
if not, when will it go into safe mode?
Old Aug 19, 2005 | 08:06 PM
migs's Avatar
Default Re: Which CEL's cause LIMP / SAFE Mode ? (P95)
What mods do you have done to your car?
Old Aug 19, 2005 | 08:36 PM
P95's Avatar
P95
Default Re: Which CEL's cause LIMP / SAFE Mode ? (migs)
stock. just an intake.
nobody knows about safe mode???
Old Aug 19, 2005 | 09:51 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P95 &raquo;</TD></TR><TR><TD CLASS="quote">
nobody knows about safe mode???</TD></TR></TABLE>
Is that when I have to restart the computer?
Old Aug 20, 2005 | 05:12 AM
MOVE OVER's Avatar
Default Re: Which CEL's cause LIMP / SAFE Mode ? (Bbasso)
hey, i have this problem too as of 2 days ago.
Old Aug 20, 2005 | 07:53 AM
Leopold Scotch's Avatar
Default Re: Which CEL's cause LIMP / SAFE Mode ? (ITR 1102)
As far as i know, anytime your car is throwing a check engine light, it will go into safe mode and dump more fuel to compensate for the problem, depending what it is. If your throwing a code due to the knock sensor your timing will automatically retard to avoid any serious problems.
Old Aug 20, 2005 | 09:16 AM
Skelly's Avatar
Default Re: Which CEL's cause LIMP / SAFE Mode ? (Leopold Scotch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leopold Scotch &raquo;</TD></TR><TR><TD CLASS="quote">As far as i know, anytime your car is throwing a check engine light, it will go into safe mode and dump more fuel to compensate for the problem, depending what it is. If your throwing a code due to the knock sensor your timing will automatically retard to avoid any serious problems. </TD></TR></TABLE>
yeah, this dude is correct. I had a bad knock sensor that i just replaced. Gas mileage is now alot better, and my car is faster also. After i installed the knock sensor I took it to acura to get the light deleted. You must go to acura because at my work we have a snap on ecu reader and it wouldent delete it for some reason.
Old Aug 20, 2005 | 02:52 PM
MOVE OVER's Avatar
Default Re: Which CEL's cause LIMP / SAFE Mode ? (Skelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skelly &raquo;</TD></TR><TR><TD CLASS="quote">
You must go to acura because at my work we have a snap on ecu reader and it wouldent delete it for some reason.</TD></TR></TABLE>
never heard of that. just disconnect the battery and pull your backup fuse. it will erase the code.
punkracer
12
Nov 2, 2006 04:09 PM
LoseRPunKx182
Aug 4, 2005 03:36 PM
onyx00
Dec 24, 2004 05:05 PM
92civeg
Dec 21, 2003 03:28 PM
cyvic
Jun 5, 2003 02:45 PM
