Modding stock dizzy cap for external coil
Old Aug 19, 2005 | 10:12 AM
X2BOARD's Avatar
Default Modding stock dizzy cap for external coil
I have the MSD power tower to put onto my stock distributor cap. It requires that I put silicone into the cavity after putting the tower in the drilled part... which needs 24 hours to dry.
I have a time/schedule problem, so I'm wondering if I put the tower onto the dizzy and NOT put the silicone on for a half day (and drive the car a few miles)... would that be kosher ?
I assume the silicone is to only seal moisture out of the drilled part ?
Old Aug 19, 2005 | 03:12 PM
X2BOARD's Avatar
sup?
Old Aug 22, 2005 | 05:13 AM
X2BOARD's Avatar
Anyone ??
Also do I need to install a resistor inline ?
Old Aug 24, 2005 | 06:15 AM
R-Toyz.com's Avatar
Seal it as it is there to protect the electricity from arcing all over the place as well, and not just moisture.
You don't need the ballast resistor on our applications.
Old Aug 24, 2005 | 01:43 PM
X2BOARD's Avatar
Default Re: (rtzcom)
thx... I took the time to silicone it before testing....
Old Aug 27, 2005 | 05:36 PM
R-Toyz.com's Avatar
good luck with your setup bro
Old Aug 28, 2005 | 09:12 PM
X2BOARD's Avatar
Thx bro... it's giving me hell.
So far the list is up to new icm, new coil, new battery... and now the alternator is kicking up..... I was forced to pull my MSD setup and threw on a stock dizzy to diagnose wtf is going on....
Well... that's what I get for not being satisfied with stock....
Old Aug 29, 2005 | 09:23 AM
R-Toyz.com's Avatar
Default Re: (X2BOARD)
Honestly, if there is nothing wrong with the stock dizzy...I'd leave it stock.
Whats the problem with the car if I may ask...I may have had the same problem before and could help you out....so you could drop the MSD back in with a quickness
Old Aug 29, 2005 | 11:51 AM
X2BOARD's Avatar
Honestly right now I'm not sure wtf is up... maybe the dizzy's pick up has gone bad.
The problem has changed over the course of my umm.... misfortune.
First the car wouldn't start, then it stopped cranking... then fixed some stuff... got it to start and drive... then the tach started going crazy at 4k + then it got worse... I swapped out icms... it went away and came back... then I swapped icms and coil... problem went away for 5 mins... then comes back at 7k+ only. THEN... the next day... car won't start again. I replace the ENTIRE dizzy... car starts and runs... but feels like it's pulling a boat. OMIG... where's my shot gun ?
I am too busy at work to keep playing this game so I've given up and will take the POS to the local Honda specialty mechanic 2mrw. (i hate going to mechanics)
Old Aug 29, 2005 | 12:01 PM
R-Toyz.com's Avatar
Are your spark plugs and wires good? Have you pulled and inspected the plugs recently?
Old Aug 29, 2005 | 01:34 PM
Flashmn's Avatar
Default Re:
Goes crazy at 4k+, like the needle darts all over the place? Sounds like an ignition module failure if that happens. Are the groundings good and checked with a multimeter? Also, I'm not sure how the module is mounted in your case, in my case in the corolla, I'm running adjustable timing management using a bosch ignition module and it has a 100% failure rate if it gets too warm and it would start to act like that, so check the mounting too and that it doesnt get too hot.
Old Aug 31, 2005 | 09:28 AM
R-Toyz.com's Avatar
any updates X2BOARD?
xlusiveracer
44
Apr 3, 2018 04:59 PM
plugger
Feb 23, 2012 07:17 PM
dmotoguy
Jul 29, 2008 08:22 PM
typeass
Mar 27, 2004 06:49 AM
JeremyL
Mar 17, 2003 04:38 AM
