trouble torquing down main bolts
Old Aug 19, 2005 | 08:29 AM
B18_Civic's Avatar
Default trouble torquing down main bolts
I am having a little trouble torquing down the main bolts on a b18a. I did the first step in order. On the second step I tried to get them down to spec. But it would click before the bolt would move. I don’t think this is right. We applied arp torque lube for "accurate" torquing. We inspected the bolt and everything is fine with them. Any help would be great. Thanks fellas.
Old Aug 19, 2005 | 11:19 AM
B18_Civic's Avatar
Default Re: trouble torquing down main bolts (B18_Civic)
to the top
Old Aug 19, 2005 | 02:32 PM
PyroProblem's Avatar
sounds like the bolts may be stretched...Are these new or used main bolts?
If used,get new ones or ARP studs...
If new, Is your torque wrench accurate? Double check it against another. Important bolts like that need to be precise. Snap=onmakes a rally nice digital one ut its a little pricy...
Old Aug 19, 2005 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: trouble torquing down main bolts (PyroProblem)
And if you did use stock bolts, your not supposed to use arp lube; your supposed to use oil.
big difference
Old Aug 19, 2005 | 07:16 PM
B18_Civic's Avatar
ok thanks guys easy fix
91tegraRS
Apr 12, 2010 08:19 AM
lude98SH
Dec 22, 2008 08:44 AM
crispydee
Jan 9, 2005 01:17 AM
oMek
May 6, 2004 01:06 PM
riceball777
Nov 12, 2003 11:26 AM
