how much hp to run 11's in a eg hatch?
Old Aug 18, 2005 | 09:25 PM
.adam.'s Avatar
Default how much hp to run 11's in a eg hatch?
i know this is a newbish question, but it would make my researching a lot easier if i knew how much horsepower i have to make to run consistent 11's. my plan is to boost a b18c1 eg hatch w/ full interior. it will mostly be a street car, but visit the track every week. i plan on using slicks w/ a traction bar. does anyone currently have this setup? im hoping i wont have to get a sleeved block, just some pistons, rods, blockguard. ill be using a gt series turbo. any help is greatly appreciated. o and if your gonna tell me to search, please dont, because i already am and have been.
-adam
Old Aug 18, 2005 | 10:16 PM
darkdayz's Avatar
Default Re: how much hp to run 11's in a eg hatch? (civicskater)
check this out
https://honda-tech.com/zerothread?id=1341719
Old Aug 18, 2005 | 10:26 PM
Adi Radoncic's Avatar
On Fire!
mid 200's whp with slicks and a good 60' can get you to the 11's..
Got to be good at the wheel thou!
Old Aug 19, 2005 | 10:03 AM
nsxmatt's Avatar
Default Re: how much hp to run 11's in a eg hatch? (Adi Raaa)
248whp, turbo B16 in a EG hatch. Times in sig.
Old Aug 19, 2005 | 10:55 AM
Team Evol Tyrone's Avatar
Default Re: how much hp to run 11's in a eg hatch? (nsxmatt)
I ran 11's with a lsvtec on the bottle. High 200 whp Im sure you don't need a sleeved block a friend went 10.8 at 134 with a b16a 20lbs stock sleeves.
Old Aug 19, 2005 | 11:00 AM
.adam.'s Avatar
wow im pretty impressed. does anyone have any suggestions on what turbo to run? i want to use a gt series because i can get a discount through garrett, but still want the t3 flange.
Old Aug 19, 2005 | 11:17 AM
DOHCarp's Avatar
Default Re: (civicskater)
I ran 11.9 all day with 268 whp stock everyhting with 7 pounds in an LS/vtec
Old Aug 19, 2005 | 11:21 AM
.adam.'s Avatar
would one of the gt32's be a good turbo? or is that too big?
Old Aug 19, 2005 | 11:37 AM
cubish's Avatar
a nice 300hp should have you running 11's and not having to drive the hell out of the car. any descent t3/t4 with pistons and rods, and a ems should do it
Old Aug 19, 2005 | 11:57 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicskater &raquo;</TD></TR><TR><TD CLASS="quote">would one of the gt32's be a good turbo? or is that too big?</TD></TR></TABLE>
You can use just about any turbo you want to reach that goal of yours..
Old Aug 19, 2005 | 11:59 AM
.adam.'s Avatar
well since it will be a dd also, i dont want anything laggy. would the gt32 be too laggy?
Old Aug 19, 2005 | 07:42 PM
It should be fine for a daily just remember maintenance is a must with anything that has a power adder.
Old Aug 19, 2005 | 08:18 PM
TrackSpeedRacing's Avatar
Our white eg with 232whp and 155wtq pulled an 11.9 at 112mph with a 1.6 sixtyfoot. Weighs about 2180lbs with driver.
Old Aug 19, 2005 | 08:28 PM
.adam.'s Avatar
is anyone on here using the same setup that im plannin on using? what kind of numbers are you making??
Old Aug 20, 2005 | 07:56 PM
back-door's Avatar
I ran 11.9 in a eg around 2,000lb onthe the motor making 223hp at R&D dyno.
Old Aug 21, 2005 | 09:21 AM
Used2beAb16's Avatar
Default Re: (back-door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by back-door &raquo;</TD></TR><TR><TD CLASS="quote">I ran 11.9 in a eg around 2,000lb onthe the motor making 223hp at R&D dyno.</TD></TR></TABLE>
hes going FI so he will mostly likely need a tad more power than that. gasp
Old Aug 23, 2005 | 02:42 PM
Miss PSI's Avatar
I'm making 304whp and knocking on 11seconds. I have a B18C1 boosted EH2.
I'm running 12.187 @118.95 with 2.0 60ft times on 22x8x13 M&H slicks.
This was my first time running with the slicks and I need to work on the slick psi and my launch.
Old Aug 23, 2005 | 03:29 PM
2point2's Avatar
what size slicks and what tranny were you guys using?
5poonhatch
Sep 6, 2006 03:18 AM
DarkBB4
Sep 28, 2005 04:49 PM
LSVTEC 91 Civic
May 19, 2005 01:04 PM
hatchboy93
17
Nov 10, 2003 10:24 PM
Nebula
Oct 13, 2001 08:23 AM
