obd2 to obd1 swap wiring
Old Aug 18, 2005 | 03:22 PM
alucardex's Avatar
Default obd2 to obd1 swap wiring
hi, i'm swaping and obd1 gsr into my 96 civic dx and don't want to spend any more money buying an obd2 distributor, alternators and injectors. I already have the jumper conversion
how do i wire my obd2 harness into:
obd1 distributor, alternators, and injectors?
help would be appreciated, thanks!
Old Aug 18, 2005 | 06:46 PM
alucardex's Avatar
Default Re: obd2 to obd1 swap wiring (alucardex)
any info? o yea i'm running the obd1 ecu that came with the engine so can i just connect the wires that i need?
Old Aug 18, 2005 | 09:43 PM
BlKdOutEk's Avatar
rywire.com has a harness for the dizzy
<A HREF="http://www.rywire.com/dizadapters.shtml
" TARGET="_blank">http://www.rywire.com/dizadapters.shtml
</A>
Old Aug 18, 2005 | 09:47 PM
BlKdOutEk's Avatar
Default Re: obd2 to obd1 swap wiring (BlKdOutEk)
http://www.rywire.com/dizadapters.shtml here is the correct url. I know u dont want to spend more money but if u cant figure out the wiring the harness is $40
Old Aug 18, 2005 | 10:29 PM
Touge Tuning's Avatar
you can use the alt off your D series, also you can swap your injectors from the D series onto your GSR engine.
Old Aug 19, 2005 | 11:32 AM
alucardex's Avatar
alright!, thanks a bunch!
jaap_15
40
Mar 10, 2011 07:44 PM
beginmyhonda
Jan 11, 2010 05:02 PM
i heart honda
Feb 13, 2009 11:47 AM
white2draccord
Nov 10, 2008 08:15 PM
cthan3o3
13
Jul 31, 2005 08:27 AM
