Help! How to remove the interior plastic panel next to rear seats in EJ8?
Old Aug 18, 2005 | 11:42 AM
camelian's Avatar
Default Help! How to remove the interior plastic panel next to rear seats in EJ8?
I've searched and found nothing on the 96-00 coupe. I'm trying to remove that big plastic panel with cup holders in the back next to the rear seats.
I've got it mostly off, most of the clips have popped off but I can't get it to slide forward or come off. Do I have to remove the rear seats? I'm trying to install the rear deck with the speaker grills etc.. Any help is appreciated!
jesse
Old Aug 18, 2005 | 01:03 PM
elitesi8's Avatar
Default Re: Help! How to remove the interior plastic panel next to rear seats in EJ8? (camelian)
Yep, gotta remove the seat and just keep pulling on it.
Old Aug 18, 2005 | 01:18 PM
northkai3's Avatar
Default Re: Help! How to remove the interior plastic panel next to rear seats in EJ8? (elitesi8)
seats
Old Aug 18, 2005 | 05:20 PM
camelian's Avatar
how do you remove the rear seats? I read something about turning the bottom cushions but i think that was for the 5th gen coupe
Old Aug 18, 2005 | 05:31 PM
dez6's Avatar
Default Re: (camelian)
There should be a 10mm or 12mm bolt on on each side where the seat meets the carpet. Take those bolts out and lift up and out on the seat.
Old Aug 18, 2005 | 08:37 PM
Civic4less's Avatar
Default Re: (dez6)
Theres a post floating around here somewhere... Lemme find it.
But until I do... pretty much just Fold down the rear seats. Remove the screws holding them in place (the "latches" or w/e are SILVER so you can miss them. Those are holding all the screws) You have to fold up the "carpet" behind them a little bit to find some of the hidden ones. Then remove those peices... then Pull on your lower seat kinda hard... and it should come out. And Vouala... no rear seats.
BTW: If I remember correctly all you'll need are 10mm and 12mm sockets? And in order to get to the part for your "rear speakers" you have to take out the whole rear interior (In this order too: Fold down part of Seats, Lower Seats, Side Panels, THEN Rear part with speaker grill)
pliskin679
May 23, 2007 06:11 PM
89sicivic
Feb 28, 2007 10:03 AM
151 Proof
Apr 2, 2003 09:26 AM
Fuster_Cluck
Dec 16, 2002 09:33 PM
JL 74
Mar 25, 2002 08:30 PM
