Piston Clearance Problem and Question for ls/vtec.
Old Aug 18, 2005 | 10:46 AM
wushubrian's Avatar
Default Piston Clearance Problem and Question for ls/vtec.
I am building an all motor ls/vtec and I wanted to use ITR pistons. I got a b16 head with the golden eagle ls/vtec kit with a stock height head gasket. I've read both that the pistons will clear and that they will not and hit the valves. Could someone please clarify this for me. Thank You.
Old Aug 18, 2005 | 07:13 PM
wushubrian's Avatar
Default Re: Piston Clearance Problem and Question for ls/vtec. (wushubrian)
TTT
Old Aug 18, 2005 | 08:19 PM
pomansouth01's Avatar
Ginger Kid
if your what cams are you running, if its just stock cams, i know that you will be ok, but anything else, just gotta ask more specifically, and search next time please.
Old Aug 18, 2005 | 08:53 PM
wushubrian's Avatar
Default Re: (pomansouth01)
I'm using ITR cams. I searched and both came up. Some ppl said they would fit and some said they wouldn't.
Old Aug 19, 2005 | 03:11 AM
PyroProblem's Avatar
Default Re: (wushubrian)
one way to be sure is to clay the engine on assy. Or if you had a Borescope, but those are like $3K+...
I think some people also use the light valvespring method and do the "click" test.
Old Aug 19, 2005 | 05:16 PM
wushubrian's Avatar
Default Re: (PyroProblem)
Does anyone no for sure if they will or will not clear?
Old Aug 19, 2005 | 07:40 PM
PogKai's Avatar
it should clear no problems.
Old Aug 21, 2005 | 07:13 PM
wushubrian's Avatar
Default Re: (PogKai)
aight cool. any other just to confirm this?
Old Aug 21, 2005 | 07:57 PM
miller.91.HB's Avatar
If you’re building an all motor lsvtec I would recommend using B16 pistons over ITR pistons. It will bump your compression up a little more. I'm running the same setup and haven't run into any clearance issues. To be exact it’s about 11.3 - 11.5:1 with PR3 pistons.
Old Aug 22, 2005 | 09:15 AM
ALMXDUPINTEGRA's Avatar
CTR pistons over ITR pistons for LS VTEC is best
Old Aug 22, 2005 | 08:38 PM
wushubrian's Avatar
Default Re: (ALMXDUPINTEGRA)
what will the compressin be with CTR pistons?
Old Aug 22, 2005 | 10:38 PM
Used2beAb16's Avatar
not ctr pistons just b16 pistons.
Old Aug 23, 2005 | 08:11 AM
mmuller's Avatar
Mad Scientist
Default Re: (Used2beAb16)
PCT pistons are not better...
people giving wrong advise...
Pr3's or p30's are the way to go.
you will have no valve to pistons contact using itr cams.
Old Aug 23, 2005 | 03:08 PM
wushubrian's Avatar
Default Re: (mmuller)
Will there be any clearance problem with b16 cams either. Migth use stock cams for a while when i'm breaking the motor in.
Old Aug 27, 2005 | 02:36 PM
wushubrian's Avatar
up
Old Aug 27, 2005 | 05:16 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wushubrian &raquo;</TD></TR><TR><TD CLASS="quote">Will there be any clearance problem with b16 cams either. Migth use stock cams for a while when i'm breaking the motor in. </TD></TR></TABLE>
If itr cams will be fine what do you think? b16 cams are much smaller and will have way more valve to piston clarance.
Old Aug 28, 2005 | 08:28 AM
wushubrian's Avatar
Default Re: (PURPLETERROR)
wow.... nice attitude....
LSVtechnologytur...
Feb 28, 2008 11:37 PM
HondaBurger
Sep 19, 2007 02:36 PM
Dan GSR
Jan 14, 2004 04:10 AM
hatchdrvr
Aug 8, 2003 04:08 PM
internet ay
Dec 6, 2001 11:00 AM
