resetting an ecu on a 89 crx si..?
Take off the negative side of the battery for 10 seconds and that will reset your ECU, or you can pull a fuse, I forgot which one.
I doubt your car will run that much better.
Search button does wonders on this forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Junkie »</TD></TR><TR><TD CLASS="quote">How do u re-set the ECU on a 89 crx si...i know i know..n00b Q..but my friend with his 2002 VW jetta 1.8t did it and his car ran HELLA better...</TD></TR></TABLE>
take off FUSE Or disconnect Battery............. i recommend you take fuse off. i dont like reseting my clock or my stereo presets hit me up i am in duncanville..........maybe we could cruise around
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote"> will reset your ECU, or you can pull a fuse, I forgot which one.</TD></TR></TABLE>
pull the ECU and hazzard fuses. that does it
