understeer help
i just started modifying/upgrading my suspension for the rsx.
going around turns and corners it's obvious a ff car will understeer.
i have installed coilovers on all four corners, and my next modification will be a rear sway bar. stiffening up the rear will probably help with the understeer, but what else can i do to improve the handling characteristics of this car?
thanks!
thanks!
Assuming that this is for a race setup and not a street/touge setup...
The best way to reduce understeer is to take a driving school. Learning to look ahead and pick a line will greatly reduce understeer. If you early apex, you will understeer.
That said, coilovers and a bigger rear swaybar will reduce understeer.
jfingers8
Mar 30, 2006 05:37 PM
