Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
understeer help
Old Aug 17, 2005 | 11:51 PM
KOREAN's Avatar
Default understeer help
i just started modifying/upgrading my suspension for the rsx.
going around turns and corners it's obvious a ff car will understeer.
i have installed coilovers on all four corners, and my next modification will be a rear sway bar. stiffening up the rear will probably help with the understeer, but what else can i do to improve the handling characteristics of this car?
thanks!
Old Aug 18, 2005 | 12:33 AM
Johnny Mac's Avatar
Default Re: understeer help (korean)
Use search, there is a plethora of handling information both in AX/RR and the Suspension forum.
Old Aug 18, 2005 | 06:23 PM
gamby's Avatar
Assuming that this is for a race setup and not a street/touge setup...
The best way to reduce understeer is to take a driving school. Learning to look ahead and pick a line will greatly reduce understeer. If you early apex, you will understeer.
That said, coilovers and a bigger rear swaybar will reduce understeer.
Old Aug 18, 2005 | 07:11 PM
CivicSiRacer's Avatar
Default Re: understeer help (gamby)
Also a little bit of toe out helps - like 1/16-1/8 toe out front and rear.
Set rear shocks to full stiff and fronts to full soft.
jdmejcivic
Nov 15, 2009 08:10 AM
jfingers8
Mar 30, 2006 05:37 PM
crooked muffler
Oct 20, 2003 07:25 PM
sambam27
Sep 10, 2003 07:39 PM
revvhappy
Apr 15, 2003 09:25 AM
