radiator fan problem...
Old Aug 17, 2005 | 06:18 PM
andreysibiris's Avatar
Default radiator fan problem...
finally i made the swap correctly and my car is running now, but the radiator fan is not working, the antifreeze is in the right level, is working fine, i have a single cam radiator and a B16 engine, do i have to change the radiator for a bigger one like gsr or b16 radiator?? because some peolple told me that those kind radiator keep more cold water....some body please...
Old Aug 17, 2005 | 06:20 PM
Toxidomask's Avatar
Default Re: radiator fan problem... (andreysibiris)
nahhh the civic half radiator works, make sure everything is plugged in. maybe you got something loose at the moment thats why ur fan is not turning on.
Old Aug 17, 2005 | 06:23 PM
Default Re: radiator fan problem... (Toxidomask)
there's next to the thermostate pump a plug that turn on or off the fans, i broke by accident just the end of the sensor, but the plug fit perfect and is not loosing or hanging...
Old Aug 17, 2005 | 06:40 PM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
check the relay to your fan. Make sure it's good. I can't read your scribble
Old Aug 17, 2005 | 07:26 PM
95DxSi-R2
Guest
Posts: n/a
this is kinda funny, make sure your thermostat pump is working correctly
Old Aug 17, 2005 | 09:39 PM
Do_Ster's Avatar
if it's not your relay, check the thermo switch, the sensor that goes into the thermostat.
Old Aug 18, 2005 | 04:32 AM
BoOstedEM1's Avatar
You can always just buy a del sol dual core for cheap and put it there and replace that sensor you broke.
Old Aug 18, 2005 | 06:50 PM
dohc_si's Avatar
no dont change the radiator just take it to a shop because its problably a wiring problem or cleaning it,,,its problably fudge..good luck
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
Mattyg2
Jun 1, 2004 02:46 PM
envious1320
Mar 9, 2003 04:50 PM
