92 Civic CX w/ B18C1 swap - which AC bracket?
Old Aug 17, 2005 | 05:26 PM
eric.'s Avatar
25 Year Member
Default 92 Civic CX w/ B18C1 swap - which AC bracket?
Searched for the answer for a few days to no avail..... here's my problem...
I have a '92 Civic CX with a 94 GSR swap. Using the D-series AC compressor, I had purchased and installed what I thought was a Del Sol DOHC VTEC AC compressor bracket. I was only able to utilize two of the four bolts to connect the compressor to the bracket. Driving home the other night I had one bolt break off, so I took off the belt for the time being so I don't break the remaining bolt and end up having to replace AC lines as well.
Is there an AC bracket that allows you to properly mount the compressor to the bracket?
Is the Del Sol DOHC AC bracket the one I am supposed to use, and I was sent the wrong bracket?
Or do I need to swap out my D-series compressor and use a B-series instead?
Thanks in advance..
Old Aug 17, 2005 | 07:02 PM
makibaka's Avatar
Default Re: 92 Civic CX w/ B18C1 swap - which AC bracket? (mood)
It sounds like you have the wrong bracket.
I have a 92 CX w/ a 95 GSR swap and used the Del Sol DOHC VTEC a/c compressor bracket. All the bolts lined up (mounting to the engine block; D series compressor mounting to the bracket). I did this a few years ago, but the bracket should have "p54" stamped on it if it's the correct bracket (can't remember if that's the correct code right now; I'll rumage through my notes and reply back). At any rate, there is a bracket that exists where all bolts line up and thread in correctly. Maybe you were given a Del Sol SOHC VTEC bracket?
So unless I missed something, it seems that you have the wrong bracket.
EDIT: corrected bracket stamp code
Old Aug 17, 2005 | 07:06 PM
makibaka's Avatar
Default Re: 92 Civic CX w/ B18C1 swap - which AC bracket? (makibaka)
Found my notes! I used the Del Sol DOHC VTEC a/c bracket stamped P54 HTH...
Old Aug 18, 2005 | 02:09 AM
eric.'s Avatar
25 Year Member
Thanks for the help, will check mine out...
Old Aug 18, 2005 | 05:19 AM
1fastVX's Avatar
Yeah you definately need the DelSol VTEC bracket! Sometimes the guys at the dealerships dont listen when you say DelSol VTEC. The part number should be the one below.
Del-Sol VTEC A/C Bracket - 38930-P54-000
John
Old Aug 18, 2005 | 07:46 AM
Falqon's Avatar
Default Re: 92 Civic CX w/ B18C1 swap - which AC bracket? (1fastVX)
I'm betting his bracket is stamped P30. A lot of people incorrectly give the advice "buy a del sol vtec bracket" they aren't all p54.
Old Aug 18, 2005 | 08:12 AM
kingleh's Avatar
na dude you need a dc bracket. hondas still run on dc power like other cars.
Old Aug 18, 2005 | 11:11 AM
eric.'s Avatar
25 Year Member
Default Re: 92 Civic CX w/ B18C1 swap - which AC bracket? (Falqon)
You are correct. Took off the compressor and found out that it was stamped P30. Damnit! I thought I had ordered a P54. I was either sent the wrong bracket or I selected the wrong one when I made the purchase online. Well, time to order the correct one AGAIN. Thanks all..
BTW, I got the "DC" joke, kingleh... (I have 14 years electronics background)..
Old Aug 18, 2005 | 06:15 PM
Falqon's Avatar
order a 94 vtec bracket and it'll be fine. Misinformation online is crazy, half of the advice your gonna get online is just people guessing.
MShonda
Nov 22, 2010 07:20 PM
Hatchb96
Sep 1, 2010 07:26 AM
1 sLoW hAtCh
May 8, 2006 05:11 AM
gp93DX
Aug 11, 2002 12:20 PM
LXguy
Feb 6, 2002 12:00 PM
