What compression ratio do B20 Vtec 9:1 pistons have in a B16 Block??
Old Aug 17, 2005 | 12:56 PM
hovic's Avatar
Default What compression ratio do B20 Vtec 9:1 pistons have in a B16 Block??
ok guys here´s my problem..
I purchased a set of 9:1 JE turbo pistons for a B20 vtec a while ago (84mm). Now I´ve got the chance to get a benson sleeved B16 block (84mm too :-)) for a good price and I want to put the JE pistons into the B16 block. I´ll go with a stock B16 head for the first time so what compression ratio will theese B20 vtec pistons have in a B16 block? Is there a way to calculate the new compression ratio?
thanx for your help!!!
Old Aug 17, 2005 | 07:42 PM
stmizner's Avatar
Default Re: What compression ratio do B20 Vtec 9:1 pistons have in a B16 Block?? (hovic)
i calculated about 7.53 or 7.42 depending if that b20vtec is supposed to have a b16 head or gsr head at 9.0 to 1
a b20 vtec would have a 9.0 cr with a b16 head if the piston volume is -12 cc and 9.0 cr with a gsr head if the piston volume is -13 cc.
if you put this into a b16 bored to 84 mm and put on a gsr head you would have 7.61 with -12cc and 7.50 with -13cc piston domes.
AdrenalineAngel
Oct 23, 2019 10:38 PM
crxclown
Jan 14, 2009 09:55 AM
SSVTi
Aug 2, 2006 08:14 AM
KillaB18
Apr 2, 2005 07:58 AM
teamrocket si
Jan 11, 2003 03:06 PM
