Stud Problem
Old Aug 17, 2005 | 09:33 AM
LSEGHATCH's Avatar
Default Stud Problem
Just installed all but one of my ARP head studs and the stud on the far left intake side won't go down all the way. It's a d15b7 by the way.
I was thinking about taping it just to clean the threads, but I don't know why it won't go all the way?
Old Aug 17, 2005 | 09:53 AM
LSEGHATCH's Avatar
Default Re: Stud Problem (LSEGHATCH)
Up, I hate to be pushy but I have to have this done by 2:00
Old Aug 17, 2005 | 11:59 AM
LSEGHATCH's Avatar
Update: Bought a tap and tapped out the thread, still it doesn't go. It has about 1/2" more but it won't budge. This is really pissing me off, do you think I could get by with using one oem headstud from when I tore it apart the first time?
Old Aug 17, 2005 | 12:27 PM
Lewdin' Incognito's Avatar
You didn't torque them down all the way as you set them in did you?
With head bolts, you want to line up the head, set ALL the bolts in their holes, tighten down to snug then torque the bolts to 1/3 of their torque specs (starting in the center and working in a "Z" pattern accross the head). Then do the same to about 2/3 of the torque specs, and finally the same pattern to the full torque spec.
This draws the head down evenly; if you torque each bolt down separately then it won't draw down right and you could very well not have matching bolt holes.
EDIT: pm answered
Modified by Lewdin' Incognito at 1:38 PM 8/17/2005
Old Aug 17, 2005 | 12:31 PM
LSEGHATCH's Avatar
Default Re: Stud Problem (Lewdin' Incognito)
Lewdin' I PM'd Ya
spazman2099
Nov 30, 2014 10:24 AM
TunerKid4lyf
25
Jul 12, 2013 08:01 AM
crxguy406
Mar 16, 2013 09:04 AM
gonmaro
Jan 29, 2009 12:05 PM
NOOTRON20
Oct 11, 2003 10:18 AM
