mini me question
Old Aug 17, 2005 | 06:40 AM
9hatch6's Avatar
Default mini me question
i got a sohc non vtec right now. y7, 96 hatch, obd2, if i throw a vtec head on thats obd1 am i gonna be going slower then i am now (sohc non vtec) thats what this kid is trying to tell me. he said he knows someone who did same swap as me and his was slower then his stock non vtec motor. is this true?
Old Aug 17, 2005 | 06:47 AM
Scrapin4DR's Avatar
Default Re: mini me question (9hatch6)
i heard that you actually gain around 25hp by doing a mine me swap , because you get the vtec if you wire it up correctly, also you can use y8 head taht's ob2 and don't have to worry about converting from ob1 to ob2
Old Aug 17, 2005 | 09:20 AM
9hatch6's Avatar
Default Re: mini me question (Scrapin4DR)
i got the z6 head. is it worth it you think?
Old Aug 17, 2005 | 09:25 AM
sohc_boy's Avatar
its worth doing the mini-me. although the stock y7 tranny is going to hold you back. i'd look for an ex tranny to go with the vtec head. biggest performance gain is gonna be a tranny swap. unless you go f/i.
Old Aug 17, 2005 | 09:35 AM
9hatch6's Avatar
Default Re: mini me question (sohc_boy)
yeah i just got a ex tranny from a 92 4dr. is that ok?
Old Aug 17, 2005 | 10:37 AM
Scrapin4DR's Avatar
i dunno if it's worthit, i was gonna do it my self , but like sohc_boy said get an ex tranny it has much shorter gears, i'm gonna do a whole d16z6 swap and just booost the bish, and for that z6 head, you know you gotta convert your car to obd1 right?
Old Aug 17, 2005 | 02:30 PM
9hatch6's Avatar
can i use obd2 wire harness and just wire vtec to ecu?
Old Aug 17, 2005 | 02:36 PM
gmcrxsi's Avatar
i have a 95 si tranny and a 97 ex tranny.... if you want either of em let me know. if i were you i would run a z6 head with a y8 intake manifold and some higher comp pistons. i have this in my rex and it runs great, only set back... zc pistons which yeild a 12+ cr in my sohc zc block, so the timing is pretty 'tarded... atleast til i get my hondata in.
Old Aug 17, 2005 | 04:49 PM
Scrapin4DR's Avatar
Default Re: mini me question (gmcrxsi)
i don't know about the obd2 wiring harness i think they make obd2 to obd1 conversion harnesses, not sure tho, somebody confirm this
Old Aug 17, 2005 | 05:23 PM
Slothy's Avatar
I gained 16hp to the wheels doing the y7/y8 mini-me. Dyno @ stock was 95hp/93ft-lbs. After the head, 111hp/100ft-lbs. My car is a 99, head is 00. Just had to run the 3 wires to the stock y8 ecu(vtec sol, vtec psi & knock). The back of the y7 block was tapped already for the kock sensor. Im happy with the results, makes the car more enjoyable.
Old Aug 17, 2005 | 05:26 PM
9hatch6's Avatar
Default Re: mini me question (Slothy)
if i get like intake, headers and **** will it be more then 111 hp?
Old Aug 17, 2005 | 05:32 PM
Slothy's Avatar
Mine has an intake, header and the head has been ported, polished and decked. Y7 has 45000miles on it. So not likely without changing internals.
Old Aug 17, 2005 | 05:38 PM
sohcvtec1995's Avatar
i dnt think obd's dont matter when it comes to the head. Also If you do the swap correctly then it will be worth it. Given that you get things at a good price. Seeing that you can get a z6/y8 for anywhere from 300-600, complete tranny and all. And when you factor out the price off all the mini me stuff it can come close to what a full swap would be.
Old Aug 17, 2005 | 06:53 PM
BauleyCivic's Avatar
Risky Business
Default Re: mini me question (sohcvtec1995)
https://honda-tech.com/zerothread?id=1315461
Waste of time and money. Turbo SOHC > Mini Me
Old Aug 17, 2005 | 09:59 PM
Default Re: mini me question (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1315461
Waste of time and money. Turbo SOHC &gt; Mini Me</TD></TR></TABLE>
Interesting. Man i missed alot in these past 30 days.
Old Aug 17, 2005 | 10:55 PM
I8Stang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scrapin4DR &raquo;</TD></TR><TR><TD CLASS="quote">i heard that you actually gain around 25hp by doing a mine me swap , because you get the vtec if you wire it up correctly, also you can use y8 head taht's ob2 and don't have to worry about converting from ob1 to ob2</TD></TR></TABLE>
Old Aug 19, 2005 | 05:44 AM
sohc_boy's Avatar
weren't you still running the long gear tranny with your mini-me? yes a turbo will be faster than a mini-me but there are people who don't want to go the f/i route. really alot of people would be happy with the mini-me and a tranny swap.
Old Aug 19, 2005 | 06:31 AM
rabius's Avatar
if its just the bare head it doesnt matter, but it does matter if you use the old parts from the 'new' head. if you retain the things like intake manifold ( and all its sensors and such ) and distributor that are obd2, you shouldnt have to worry about converting.
Old Aug 19, 2005 | 07:19 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">
weren't you still running the long gear tranny with your mini-me?</TD></TR></TABLE>
No, I had a Z6 tranny and an exospeed stage 2 cam.
yes a turbo will be faster than a mini-me but there are people who don't want to go the f/i route.</TD></TR></TABLE>
What, the people that want to go slow? Theres absolutely no reason to do it.
really alot of people would be happy with the mini-me and a tranny swap.</TD></TR></TABLE>
No they wouldn't.
Old Aug 19, 2005 | 07:35 AM
sohc_boy's Avatar
lol, you sound a lil bitter towards the mini-me.
Old Aug 19, 2005 | 07:39 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">lol, you sound a lil bitter towards the mini-me.</TD></TR></TABLE>
Its just worthless. Its a lot of time and money wasted for little results. I was amazed at how much only 3 psi did for my car (i'm on 6 now). Boost &gt; *
Old Aug 25, 2005 | 12:03 PM
racer_X_123's Avatar
Default Re: mini me question (rabius)
So if all i do is swap the heand and keep intake manifold the same and all, i could jsut get an obdII ex ecu and wire v-tec and not have to convert to obdI. I have a 97 civic LX Y7 and i want to convert to z6. am i going to have to go to obdI is the real question i guess
MrExclusive
Feb 3, 2010 04:09 PM
egvtec
Dec 8, 2008 06:01 PM
nnguyen22
Nov 23, 2008 05:51 PM
crazyek9
Dec 14, 2007 11:57 AM
97DX
Nov 21, 2002 08:06 AM
