is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95
Old Aug 16, 2005 | 07:51 PM
alexsracing's Avatar
Default is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95
Old Aug 16, 2005 | 08:08 PM
SOHCmaster's Avatar
Default Re: is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95 (alexsracing)
D-series fits all
Old Aug 16, 2005 | 08:22 PM
jdmegcivic95's Avatar
Default Re: is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95 (PK SPEED)
all d series are the same
Old Aug 16, 2005 | 08:26 PM
rabius's Avatar
the beauty of honda motors. in series interchangeability is great. so inter-series changeability too i think.
Old Aug 16, 2005 | 09:11 PM
Mwsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">D-series fits all</TD></TR></TABLE>
96-98*(im guessing through 00 aswell.)
dx uses a different flywheel, I know for a fact...
What you SHOULD have said was,
D-series flywheels fits all crank bolts, the PP from the y8/VTEC will not fit on the 96^.
I know from experience.
Old Aug 16, 2005 | 09:24 PM
Bond's Avatar
Default Re: is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95 (Mwsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mwsol &raquo;</TD></TR><TR><TD CLASS="quote">
I know from experience. </TD></TR></TABLE>
True, but you forgot the main question. D series parts from a specific gen will fit all models. Yes, the 1.5L fly will fit the 1.6L for the 92-95's and is not different. The problem of fitment and compatibility becomes a problem when you start bolting on parts from different gen's of the d series.
Old Aug 16, 2005 | 09:44 PM
95jeremie's Avatar
Default Re: is the 1.5 non-vtec flywheel the same as the 1.6 vtec flywheel?? 92-95 (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">
True, but you forgot the main question. D series parts from a specific gen will fit all models. Yes, the 1.5L fly will fit the 1.6L for the 92-95's and is not different. The problem of fitment and compatibility becomes a problem when you start bolting on parts from different gen's of the d series.</TD></TR></TABLE>
Old Aug 17, 2005 | 03:45 PM
so thats a yes
Old Aug 17, 2005 | 04:22 PM
racerpat94's Avatar
1.5 and 1.6 flywheels are definately compatable, but definately different in regards to weight. the cx flywheel(from the d15b8) weighs about 4-5lbs less than the ex/si flywheel. i have held both in my hands. i do not know about the dx/lx flywheel tho.
Old Aug 17, 2005 | 09:22 PM
Bond's Avatar
Default Re: (racerpat94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerpat94 &raquo;</TD></TR><TR><TD CLASS="quote">1.5 and 1.6 flywheels are definately compatable, but definately different in regards to weight. the cx flywheel(from the d15b8) weighs about 4-5lbs less than the ex/si flywheel. i have held both in my hands. i do not know about the dx/lx flywheel tho. </TD></TR></TABLE>
Dx Cx and Lx are all the same wieght. Si and Ex are heavier. It really doesn't matter on the weight though. Not to metion if it was a problem get a lightweight fly like I did. Much better then a stock flywheel IMO.
Boostage
Jul 5, 2007 03:01 PM
crazi92hb
12
Aug 21, 2005 03:29 PM
rasinhell
Jan 24, 2005 06:18 PM
mrx
Oct 1, 2004 11:17 AM
yellowbuffalo
Jun 20, 2003 04:45 PM
