lightened flywheel?
Old Aug 16, 2005 | 12:18 PM
HitEm'Up's Avatar
Default lightened flywheel?
B Series weighs - 7.5lbs
Looking at buyin one for a stock GSR motor.. Is this to light for just street use??
Old Aug 16, 2005 | 01:55 PM
JDMSiGuy17's Avatar
Default Re: lightened flywheel? (HitEm'Up)
well everyone has their own opinions on lightened flywheels. but if you ask anyone that has a lightened flywheel on their own personal car they will almost all tell you that they love it! i have one in my car and i love it and i honestly have no regrets about putting the flywheel on my car seeing as i needed to replace my slipping stock clutch anyways! but i would totally recommend the flywheel i have which is a fidanza 8lb flywheel for my b16! good luck with whatever you choose!!!
Old Aug 16, 2005 | 02:25 PM
SpoolnEG6's Avatar
Default Re: lightened flywheel? (JDMSiGuy17)
I have the 7.5lb fidanza in my ITR and it feels like it should've been there from factory
Old Aug 16, 2005 | 06:40 PM
Sam92Teg's Avatar
Default Re: lightened flywheel? (SpoolnEG6)
7.5 Fidanza here on my B18A and I love it, no drivability issues what so ever.
Old Aug 17, 2005 | 08:18 AM
BigBodySmith's Avatar
I have an ACT Prolite flywheel, and I LOVE IT!!!!
Old Aug 17, 2005 | 08:21 AM
HitEm'Up's Avatar
Default Re: lightened flywheel? (Sam92Teg)
Cool!! thanks guys
Old Aug 17, 2005 | 12:41 PM
EG_H2B's Avatar
i like 7lbs flywheels on race cars and 10lbs on street cars. i have always gone that way. 10 lbs on a street car does not wanna stall the car like a 7lbs.
Old Aug 17, 2005 | 12:46 PM
Hybrid96EK's Avatar
Default Re: lightened flywheel? (JS_TypeR)
I run the ACT prolite on my ride as well with ALMOST no issues .. My issue is something I am sure most of you never run into, since a lot of people rip off thier AC system.. Anyways, the problem I have is when the AC is on, if you are cruising along say 4,000rpms+ and then push in the clutch to come to a stop, the engine will die. With the AC on, it spins down VERY quickly. I would say approx 2,000rpms a second. Anyways, other then that, I like it alot.
Old Aug 17, 2005 | 01:02 PM
jdmsiR20's Avatar
Default Re: lightened flywheel? (Hybrid93Eg)
^^ yeah that may happen with a really light flywheel...
just head into the stop while still in gear and pull it out at a lower rpm
11lb. on my d15b was great
8lb. on my gsr..... (i'll let you know this weekend)
Old Aug 17, 2005 | 01:09 PM
EVOLUTIONINNYC's Avatar
ACT prolite in my stock GSR. it does die alot faster which sucks cause it looks like you cant drive stick, but the real test will come when i've met the 500 mile break in period
Old Aug 17, 2005 | 01:42 PM
HitEm'Up's Avatar
Default Re: lightened flywheel? (jdmsiR20)
Yeah! let me know i just ordered one
Old Aug 17, 2005 | 02:44 PM
b18_4door's Avatar
I have exedy lightened fly...with crower stg 2 cams..car idled really low, and when i would get on it, and lets say get off it and put clutch in, it would die...so i just turned up the idle a tish and walla..every thing is perfect
I love the flywheel never go back to heavy *** 20lber this is on a b18 btw
Old Aug 18, 2005 | 07:05 AM
HitEm'Up's Avatar
Default Re: (b18_4door)
Would the lightened flywheel hurt the tranny at all??
Old Aug 18, 2005 | 09:01 AM
EG_H2B's Avatar
Default Re: (HitEm'Up)
nope
Old Aug 18, 2005 | 03:19 PM
new2novas's Avatar
I love my spoon flywheel, except the ac problem....works fine when cruising...i had been trying to figure out what the problem with it was, the other day i thought of the flywheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">I run the ACT prolite on my ride as well with ALMOST no issues .. My issue is something I am sure most of you never run into, since a lot of people rip off thier AC system.. Anyways, the problem I have is when the AC is on, if you are cruising along say 4,000rpms+ and then push in the clutch to come to a stop, the engine will die. With the AC on, it spins down VERY quickly. I would say approx 2,000rpms a second. Anyways, other then that, I like it alot. </TD></TR></TABLE>
Old Aug 18, 2005 | 03:27 PM
Hybrid96EK's Avatar
Default Re: lightened flywheel? (new2novas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by new2novas &raquo;</TD></TR><TR><TD CLASS="quote">I love my spoon flywheel, except the ac problem....works fine when cruising...i had been trying to figure out what the problem with it was, the other day i thought of the flywheel
I think I know how this can be solved... Gimme some time to test a few things.
dragonjay006
Nov 22, 2009 08:03 PM
lilo_goki
24
Mar 18, 2008 06:37 PM
immalooser
Oct 18, 2005 08:08 PM
