What's the best setup with CTR (Civic Type R) Pistons?
Old Aug 16, 2005 | 10:24 AM
Addicted2Racing's Avatar
Default What's the best setup with CTR (Civic Type R) Pistons?
98 Integra Type R with Civic Type R pistons, what other parts need to be switched out to run better with the CTR pistons? Thank you!
Old Aug 16, 2005 | 10:32 AM
Jowee's Avatar
Default Re: What's the best setup with CTR (Civic Type R) Pistons? (Addicted2Racing)
Full Race top mount
GT35 ball bearing turbo
Trust front mount
Old Aug 16, 2005 | 10:33 AM
Dave_B's Avatar
That Mad TiGhT vTaK chip WItH sOme nOs and lot's O jAsMa products.
translation..... What are your goals? what is your current setup?
Old Aug 16, 2005 | 10:40 AM
Default Re: (Dave_B)
Prefer N/A
I mean as far as injectors and I use stock? Fuel Pump? Fuel Rails? ......
Old Aug 16, 2005 | 10:44 AM
Jowee's Avatar
Default Re: (Addicted2Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Addicted2Racing &raquo;</TD></TR><TR><TD CLASS="quote">Prefer N/A
I mean as far as injectors and I use stock? Fuel Pump? Fuel Rails? ......</TD></TR></TABLE>
You'll probably get better luck posting in the All Motor forum. You can use stock or you can use 440s, hell go as high as your heart desires since you're going to need tuning done anyways with compression that high. If you plan to get big cams, get a 255 fuel pump. Your stock fuel rail can support more hp than most N/A engines can put out, but if you need the bling go for it.
Once again, you haven't stated what you want or where you want to go with this which leaves a ton of questions left in the air.
Old Aug 16, 2005 | 11:03 AM
Chris N's Avatar
You guys are retarded.
The first you thing is that they bump up the compression quite a bit (12.5:1 and 12.8:1 for OS, i think?), and you'll need a much bigger cam so you're not undercammed.
You'll need a whole host of other things in order to get it right....none of which i know anything about.
Don't just slap them in - do a bunch of research please.
Old Aug 16, 2005 | 11:06 AM
Jowee's Avatar
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">You guys are retarded.
Right you are Chris
Bradstard's Avatar
Default Re: (Jowee 1162)
You will not need a fuel pump or fuel rail (I'm still running a stock fuel pump and fuel rail with a much bigger n/a setup). If you have more compression you can usually run a little bit bigger cam. I would also get some 310cc injectors and some form of a tunable ECU. Talk to your tuner and find out what they recommend.
Old Aug 16, 2005 | 11:09 AM
Default Re: (Bradstard)
I got AEM EMS and AEM Fuel Rail, 255 Fuel Pump already. Just wondering if I need any other stuffs. Thanks
Old Aug 16, 2005 | 11:13 AM
bitzbp's Avatar
I'm running that setup in my ITR now and you don't need the fuel rail or the fuel pump, but you can use it if you want. I would personally sell the rail and the pump and put the money towards tuning the EMS for the setup or put it toward a nice header or big cams.
Old Aug 16, 2005 | 11:28 AM
Jowee's Avatar
Default Re: (bitzbp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Addicted2Racing &raquo;</TD></TR><TR><TD CLASS="quote">98 Integra Type R with Civic Type R pistons, what other parts need to be switched out to run better with the CTR pistons? Thank you! </TD></TR></TABLE>
First question. Define better.....is it running bad as it is right now?
2nd, is the car for sale in your sig? If so, why would you want to modify it or are you trying to fix an existing problem?
Old Aug 16, 2005 | 11:36 AM
Eva01's Avatar
With CTR Pistons at the least I would get, Larger Injectors, Larger Cams, and upgraded Exhaust and tuning.
Old Aug 16, 2005 | 11:50 AM
I'm buying this car from my friend that he never finished the project and I'm just gonna drive it for a while and put it up for sale. The car is running fine but he never tuned it and I just dont want to drive it someday and something gone bad. Thanks guys for your reponse!
blueskiesfade609
Mar 10, 2005 05:56 PM
motore
36
Sep 1, 2003 06:06 PM
lsvtec0394
Aug 6, 2003 01:30 PM
LSVTEC96HB
Jul 8, 2003 09:12 AM
-Racer X-
25
Apr 9, 2002 06:42 PM
