LS/VTEC PISTONS Q...
Re: LS/VTEC PISTONS Q... (-Racer X-)
the compression will be really really high thats why you will need high octane fuel. Or you can use a multi-layer head gasket. And retard the timing too...
the CR will be like 12:1 and up. different pistons in different engines is a diff CR. which head you use should make it diff also.
ctr piston in a LS = 12.4-12.5 compression ratio. This is FINE on Pump gas, just make sure you get the car tune.
Re: LS/VTEC PISTONS Q... (SiBirdie)
i know this guy thats running CTR pistons in his lsvtec on an integ chasis, one fast as car.... but he had to run on race ruel on the streets. i think itr will be better for you
Re: LS/VTEC PISTONS Q... (aNaRcHyiNmYeK)
ctr wont be too extreme if you use a thicker headgasket, also what head are you planning on running? B16 head will lower compression while GSR head will raise it
