LS/Vtec Opinions
Was wondering what you guys thought about this setup. Should I change anything? Needs to be a daily driver with decent power.
B16a head
Crower Titanium Retainers
Crower Dual Valve Springs
Big bore throttlebody
Ported & Polished
Stock cams right now but have Stage 3 drag cams with cam gears
AEM FPR
B18a block
Balanced and blueprinted
Knife edged & micropolished crank
CTR pistons
Shot-peened rods
New oil-pump, waterpump and t-belt
Lightened flywheel
DC Sports 4-2-1 header
Greddy Midpipe
UltraFlow exhaust
J1 tranny with ACT clutch and PP
B16a head
Ported & Polished
AEM FPR
B18a block
CTR pistons
Shot-peened rods
Lightened flywheel
Greddy Midpipe
UltraFlow exhaust
I sure hope you have some good gas up there.
Your compression is going to be through the roof with CTR pistons, not to mention the overall piston design of the PCT's is inferior to say a P30.
I recommend using P30 pistons, and milling the head to achieve your desired compression ratio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenboi »</TD></TR><TR><TD CLASS="quote">Was wondering what you guys thought about this setup. Should I change anything? Needs to be a daily driver with decent power.
B16a head
Big bore throttlebody <--- what intake manifold will you use
Ported & Polished
AEM FPR <--- waste of money
B18a block
Balanced and blueprinted <--- waste of money
Knife edged & micropolished crank <--- waste of money
CTR pistons
Shot-peened rods <--- waste of money, but make sure to get new rod bolts
Lightened flywheel
DC Sports 4-2-1 header <--- wrong header collector too small
Greddy Midpipe
UltraFlow exhaust
You also forgot:
New head studs (GSR)
Vtec oil supply kit (you can either make it or use GE's)
LS Headgasket
Stepped dowel pins
B16a head
Ported & Polished
B18a block
CTR pistons
Lightened flywheel
Greddy Midpipe
UltraFlow exhaust
You also forgot:
LS Headgasket
Stepped dowel pins
Do you think this is from a bad head gasket?</TD></TR></TABLE>
More likely you just need to replace the cam seal.
or it could be the Vtec solenoid gasket, JDM B16A VTEC solenoid uses the 91 NSX P/N 15825-PR3-005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenboi »</TD></TR><TR><TD CLASS="quote">If an AEM FPR is a waste of money, what would be better?</TD></TR></TABLE>
Why do you need to upgrade? What's wrong with the stock one?
Modified by miller.91.HB at 11:56 AM 9/6/2005
ended up getting a B&M FPR. i got it because my car was getting horrible gas millage, about 240kms a tank on 94. the FPR and VAFC gave my tuner a much easier time.
VtecDA9
Nov 20, 2003 12:50 PM
PearlCrx
Sep 14, 2003 06:58 AM
