In Desperate Need of a ECU pin or 2
Old Feb 22, 2002 | 03:59 PM
Loaded Butane's Avatar
Default In Desperate Need of a ECU pin or 2
I am in dire need of a ECU pin or 2 with some wire attached to it or not. I would be willing to send someone a SASE with a couple bucks in it for one or 2. My pin is messed up and none of the yards around here have any. Either email me at myrexneedsboost@aol.com or post here. Thanks for any help.
Old Feb 22, 2002 | 04:44 PM
kyler's Avatar
Default Re: In Desperate Need of a ECU pin or 2 (Loaded Butane)
i have none for you but this works well in a pinch:
get your hands on a couple 1/8" female spade connectors (like the kind you'd put on a speaker, but the smaller ones commonly used for tweeters).. cut in half the long way with strong wire snips, or a dremel with a ceramic disc... then carefully pinch the "u" thats left on one of the halves until it fits snugly onto the pin in the ecu.... then solder your wire on it and once the plug is on the ecu, push it into the empty hole on the plug with a jewlers screwdriver...
yes it sounds like a pain but it works like a charm and isn't going to come off if you do it right...
Old Feb 22, 2002 | 04:47 PM
fixhondas's Avatar
What pin?
Old Feb 22, 2002 | 07:07 PM
i think i got some on the way. I can wait on the pins cause I am waiting on a radiator at the moment.
Old Feb 23, 2002 | 01:15 AM
Blown90hatcH's Avatar
Is this for OBD0 88-91? I have about 3 sets of ecu plugs. Give me 1 dollar in a SASE and you can have an entire plug with a bunch of wires.....or you can have 2....
Old Feb 23, 2002 | 11:49 AM
Default Re: In Desperate Need of a ECU pin or 2 (Blown90hatcH)
Yea Blown it is for a 88 CRX DX with a ZC swap. Email me (myrexneedsboost@aol.com) your info and I'll send you a SASE too. I'm gonna get a few of these cause a friend is looking at a Civic DX to do a ZC swap into and we will prob need a pin or 2 for that swap too. If I could get a whole B Plug that would be great. A bunch of soldering does not scare me. Thanks a lot.
Old Feb 23, 2002 | 12:26 PM
MysteryWagon's Avatar
Is Jason not wonderful or what. haha
Old Feb 23, 2002 | 03:18 PM
Default Re: In Desperate Need of a ECU pin or 2 (ShaggenWaggon)
Yup its great that some people will help a person in need.
Old Feb 23, 2002 | 05:08 PM
Yeah....I have the entire B plug if you want it. Check your email...
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
BlackHXCoupe
Jan 19, 2010 11:08 AM
type Gendy
Feb 28, 2004 09:37 PM
FourthGenHatch
21
Apr 17, 2003 04:35 PM
