Bitch Pin?
Old Aug 15, 2005 | 06:30 PM
BigDawwg6969's Avatar
Default Bitch Pin?
Is this the roll pin that connects the shift linkage? If so... how do u get this damn thing out?! Thanks!
Old Aug 15, 2005 | 06:40 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Bitch Pin? (BigDawwg6969)
yes it is... use a tapered roll pin punch... if you're dropping the tranny then you might as well remove it when the tranny's off the block because you'll be down there under the car beating the shiet out of it and it won't even budge unless you have enough room and leverage to pound it.
Old Aug 15, 2005 | 06:47 PM
drdisco69's Avatar
Default Re: Bitch Pin? (BrokeAssPinoy)
Yes, it's much easier to take out with the trans out of the car.
Old Aug 15, 2005 | 07:52 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
haha... go to your local snap-on dealer and buy a roll pin punch to put in a air chisel and it comes right out with eeeeezzzzzz
Old Aug 15, 2005 | 08:32 PM
ThatRicerDaniel's Avatar
Default Re: Bitch Pin? (1QwIkEf)
I just use a bolt that fits through the linkage but still mates the pin. easy.
Old Aug 15, 2005 | 08:34 PM
HBK's Avatar
HBK
Default Re: Bitch Pin? (ThatRicerDaniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatRicerDaniel &raquo;</TD></TR><TR><TD CLASS="quote">I just use a bolt that fits through the linkage but still mates the pin. easy.</TD></TR></TABLE>
^^^ exactly. Get a spare bolt that bolts into the other shift linkage arm, and hammer that bitch at the pin, works every time, just dont get too frustrated.
Old Aug 15, 2005 | 11:02 PM
Smokinsax's Avatar
The Boot
i used an AC bolt, twice now, works pretty good i guess. It def. is easier when its out of the car.
Old Aug 16, 2005 | 09:56 AM
LoneStarCRX's Avatar
Default Re: Bitch Pin? (HBK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">^^^ exactly. Get a spare bolt that bolts into the other shift linkage arm, and hammer that bitch at the pin, works every time, just dont get too frustrated.</TD></TR></TABLE>
Can you explain this? Here's the diagram and we are trying to take out #29. Are you saying use #30 or #26?
Old Aug 16, 2005 | 09:58 AM
turbohappy's Avatar
Default Re: Bitch Pin? (dewarcr)
I use a 1/4 inch punch. Usually pops out in 2-3 light hits, no problem
Old Aug 16, 2005 | 09:59 AM
HBK's Avatar
HBK
use #30, but make sureu have a spare or two because it will strip/round out.
warning: watch your fingers
spens 91 Ef
19
Jan 8, 2009 07:14 PM
mstewar
Mar 3, 2006 12:23 PM
J4k3
11
Feb 27, 2006 06:46 PM
tegmech
Jun 14, 2004 10:29 PM
AzN_Flava
Mar 2, 2002 07:50 PM
