TDC position timing (error code 8)
Old Aug 15, 2005 | 06:05 PM
timntam's Avatar
Default TDC position timing (error code 8)
Hi,
I just bought a 1991 civic HB 1.5 - stock, and am getting trouble code 8, I looked it up and it is the TDC position timing, has anyone else had this problem, any repair tips would be appretiated, would it most likely be the timing belt itself or the sensor?
Old Aug 15, 2005 | 09:05 PM
WHITE HYBRID EG6's Avatar
im on that same mission rite now i have a b16 in a eg wow i need help 2 aaaahhhhhh were the tech's @
Old Aug 15, 2005 | 11:20 PM
mtber's Avatar
Default Re: TDC position timing (timntam)
Try another distributor :-P
Old Aug 16, 2005 | 05:56 AM
JimBlake's Avatar
CYP, CKP, & TDC sensors are in the bottom of the distributor. You can check for loose/dirty/corroded wiring, but I think you can't buy those sensors separately. You probably can buy a distributor without the coil & ignitor...
Old Aug 18, 2005 | 01:13 PM
miniorf's Avatar
yup im doing a b16 swap into a 77 mini and i just finaly got a light hoocked up afer a month and a half fighting with every aspect of the engine.........mine wont start cuz teh injectors fire all together each time a cylender comes up to tdc, flooding teh engine.. so if any one has any advice it would help us all out. Thanks
stopltracr
Jan 25, 2016 04:35 PM
notsolfast
Engine Management and Tuning
May 25, 2012 01:40 PM
sitrucjr
Feb 19, 2004 07:42 PM
Eg6_JDM
Sep 26, 2002 09:26 AM
