crank pulley?
Old Aug 15, 2005 | 05:46 PM
IA95civicDX's Avatar
Default crank pulley?
ok i have a jdm d15b and i have to remove the crank pulley so i can replace the timing belt cover because there is a hole in it. i was wondering if the is some special wat to keep it from turning. also wondering if my d15b7 timing belt cover will fit on the d15b?
thanks for any help, sean
Old Aug 15, 2005 | 07:39 PM
Default Re: crank pulley? (IA95civicDX)
help me please!!
Old Aug 15, 2005 | 08:10 PM
B_series_'s Avatar
the timing belt cover should fit, and for the pulley, impact.
Old Aug 15, 2005 | 09:28 PM
dohcdelsol's Avatar
Default Re: crank pulley? (B_series_)
Honda has a special tool that actually grabs the pulley and doesnt let it spin so you can break the bolt lose without cranking on the engine.
Ur deff. going to need something like an impact for this job
Old Aug 15, 2005 | 09:32 PM
handa's Avatar
Default Re: crank pulley? (dohcdelsol)
impact gun is the best. although i remember trying to put in gear and press on the breaks..i forgot if it worked or not.
Old Aug 15, 2005 | 09:47 PM
nocturnaldragon's Avatar
check my sig and search next time this is covered litterly like 20 times a week.
Old Aug 15, 2005 | 09:54 PM
Bond's Avatar
Default Re: crank pulley? (handa)
I had my Z6 out for a build and just locked the flywheel up with a screw driver and a piece of pipe. It's hard to explain, but I'll try. It looks like this O. <----now see the dot. Put a little peice of pipe with the hole facing up. Can be used the same way if the engines in the vehicle, just use a longer pipe. Now get one of the teeth to rest horisontally on the pipe and apply pressure. It should hold it nice. You can also put a screw driver through one of the teeth to help out. Now giver hell and it will come loose. So basically the pipe is vertical and the fly's tooth is resting on top of it. Good luck.
Old Aug 16, 2005 | 11:30 AM
BoOstedEM1's Avatar
Default Re: crank pulley? (Bond)
YEah there is actually a tool for that...
Old Aug 16, 2005 | 12:03 PM
The Internet Tough Guy's Avatar
Default Re: crank pulley? (BoOstedEM1)
don't put a screw driver in the flywheel teeth. it works, but it's very possible you'll break something and have a bigger mess on your hands.
search google for honda crank pulley tool, and fork over the 30 bucks for one.
Old Aug 16, 2005 | 04:06 PM
Default Re: crank pulley? (The Internet Tough Guy)
thanks for the help i got it today with a impact wrench and put a punch through one of the wholes on the pulley and able to wedge it against the block
Old Aug 16, 2005 | 05:45 PM
Grrrrrrrrrrrrr, why dont you fools just rent the right tool?!
Old Aug 16, 2005 | 05:48 PM
Lord Helmet's Avatar
Default Re: crank pulley? (nocturnaldragon)
This is what I use: http://www.thetoolwarehouse.net/shop/AP-7809.html cheaper then buying a impact gun and the air compressor that's needed for it.
Powered by VTEC
Jan 29, 2008 05:58 PM
1994CivicGS-R
Mar 19, 2006 08:06 PM
1994CivicGS-R
Mar 14, 2006 03:05 PM
NAZC
11
Jan 15, 2003 04:52 AM
Silude
Jun 4, 2001 08:31 PM
