Any links on how to install a header on a GSR!
Old Feb 22, 2002 | 02:18 PM
GSR2001's Avatar
Default Any links on how to install a header on a GSR!
Yeap, I'm a newbie when it comes to Honda/Acuras. Need tips on how to installed the DC 4-1 Header. I know is not that hard I just don't want to mess up the O2 Sensor. Thanks.
Old Feb 22, 2002 | 02:50 PM
RedStarGsr's Avatar
Default Re: Any links on how to install a header on a GSR! (GSR2001)
um... i wil try and help. first unbolt the heat shield, should be 3 , 12mm bolts. it is the thing you see that looks aluminum. next jack up the car and unbolt the header from the cat. then unbolt the bottom part of the header from the top part, should be 3 14mm's. next unbolt the 9 12's holding the header to the engine. pull all of that out. now here comes the fun part....
you might have to 'notch' the crossmember ( w/ a dremel or something ) b/c the 4-1 headers will barely fit in there. it is very hard to make everything fit ( i just did the install 2 nights ago ) and be sure to have some spare jacks ( have the car on jackstands ) and a friend to help out. good luck man, that's about all ican say. --later.
Old Feb 22, 2002 | 02:58 PM
nwarp's Avatar
Default Re: Any links on how to install a header on a GSR! (RedStarGsr)
http://www.c-speedracing.com click on "how-to" this is a pretty informative site, hope this helps
Old Feb 22, 2002 | 04:17 PM
GSR2001's Avatar
Default Re: Any links on how to install a header on a GSR! (SPOON SPEC DC2)
Thanks for the info.
Old Feb 22, 2002 | 06:35 PM
1fastGSR's Avatar
New User
Installing a new header should be a nor brainer!
Old Feb 22, 2002 | 08:08 PM
RedStarGsr's Avatar
Default Re: Any links on how to install a header on a GSR! (1fastGSR)
um.......ever tried a 4-1? no brainer eh? go ahead have fun.
Old Feb 22, 2002 | 09:09 PM
b18bvtec4drteg's Avatar
Just installed it last week. I had to unbolt the top where the 2 radiator mounts and move the radiator to the right a bit. You dont have to remove the radiator tho. The header should be brought from the bottom and start off by sliding the header to the left. It will scratch a lil if you have a A/C compressor. Wiggle it a bit and should the there no probs.
24TEN
Honda Fit
20
Sep 18, 2011 04:48 PM
2ndgent3g
Jan 5, 2007 03:35 PM
Rukusmasta2
Feb 3, 2003 07:55 AM
JSJ EG6
14
Sep 5, 2002 01:38 AM
Kellindal
Sep 22, 2001 12:25 AM
