D16y8?
Old Aug 15, 2005 | 12:22 PM
Curbow_USMC's Avatar
Default D16y8?
if i put a D16y8 motor will i get about 230hp with a ported and polished head and a skunk2 cam gear, p20 ECU with hondta, and then go turbo? or would i get more power by doing a mini me with putting the y8 head on my y7 block and doing all of the same work?
thanks,
Curbow_USMC
SemperFi
Old Aug 15, 2005 | 12:43 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: D16y8? (Curbow_USMC)
Mini-me = waste of time/money
Right Dustin?
Old Aug 15, 2005 | 12:51 PM
haveaniceday's Avatar
Default Re: D16y8? (SkoundrelUSA)
i suggest the ex transmission .. then the head .. the head alone gains will probably be worthless .. or just tranny then boost
Old Aug 15, 2005 | 01:21 PM
douspray's Avatar
Default Re: D16y8? (haveaniceday)
230WHP shouldn't be that hard with the right turbo. i've got the greddy kit on my a6/z6 and at 12 psi i put down 218 to the wheels and my turbo is tiny!
Old Aug 15, 2005 | 02:38 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: D16y8? (douspray)
230whp out of a NA Y8 is gonna cost $10K.
You would need a cam that only idles at 2K RPM and a 13K RPM redline
now a boosted Y8 could do it, not on stock internals for very long though.
Old Aug 15, 2005 | 03:18 PM
Kista20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday &raquo;</TD></TR><TR><TD CLASS="quote">i suggest the ex transmission .. then the head .. the head alone gains will probably be worthless .. or just tranny then boost </TD></TR></TABLE>
I agree... do the transmission first then go from there.
Old Aug 15, 2005 | 03:46 PM
Deemeetree's Avatar
Electrician
Just turbo your engine now and drop an EX transmission.
Old Aug 15, 2005 | 03:52 PM
SOHC4life 96's Avatar
Default Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Just turbo your engine now and drop an EX transmission.</TD></TR></TABLE>
Yup, VTEC is overrated. If you have it already, great. If you don't, who cares.
Old Aug 15, 2005 | 03:53 PM
Default Re: D16y8? (Kista20)
would i not just come out better getting a whole y7 and tranny? and also if i build and at least port and pollish and put a skunk2 cam gear will the valve trann hold up 6-8 bls of boost?
Old Aug 15, 2005 | 04:21 PM
NIGHTRIDER27's Avatar
if your going to Port and polish the head and put in a new cam put new springs it , you already got it apart ,
Old Aug 15, 2005 | 04:53 PM
Kista20's Avatar
the y8 tranny is geared a lot better than the y7, your car will be a little faster just be swapping it out.
Old Aug 16, 2005 | 08:05 AM
ok, i think i will put a the full y8 motor and trannyin my car
Old Aug 16, 2005 | 09:16 AM
chinkest_raver's Avatar
well putting 230 to the wheels, its impossible! Well maybe for the first 10 runs!! You will tear your internals up with out a full rebuild! Your stock internals are only made to handle soo much, think about it, research, it'll make you think more, and more, and more. Eventually you get answer! (someday)
Old Aug 16, 2005 | 09:23 AM
Default Re: D16y8? (*****est_raver)
ok, thanks
Old Aug 16, 2005 | 09:46 AM
I hope your talking about using a Turbo cam, if you're talking about a skunk2 stage 1,2....etc cam then your not gonna make that kind of power. The profiles of those cams will **** you up.
style'n_DC2
Jan 17, 2009 12:33 AM
jr_deleon
Nov 13, 2008 11:29 PM
Dasfinc
13
Dec 7, 2007 04:51 PM
crxnightrider
May 20, 2007 12:44 PM
awdriscol4
28
Mar 5, 2005 10:13 PM
