Questions about what wiring harness I need to use?
Old Aug 15, 2005 | 09:36 AM
speedy108's Avatar
Default Questions about what wiring harness I need to use?
I have a 93 civic EG DX that I am doing a swap in. The motor itself will be a '98 JDM Type R Block and a '99 GSR head with the GSR tranny also. I will be using a P28 ECU with Neptune. Will I just need the motor harness? and what harness would you all recommend to use with this setup (OBD1 or OBD2 GSR)?.
The only other thing I need to know is, someone told me that I didn't need to use the crank angle sensor that is down by the crank pulley. Is this true?.
BTW: I also am in need of the motor harness if someone has one available.
Thanks a lot guys, Michael
Old Aug 15, 2005 | 10:01 AM
2lua's Avatar
Default Re: Questions about what wiring harness I need to use? (speedy108)
use your own harness, go obd1, and no you don't need the crank angle sensor for obd1.
Old Aug 16, 2005 | 12:04 PM
speedy108's Avatar
Default Re: Questions about what wiring harness I need to use? (2lua)
Go with OBD-1 even though the distributor is OBD-2? will it plug right into that harness?
Thanks
TravisBiggie
May 24, 2012 07:13 AM
integra_661
May 13, 2009 10:48 PM
Blue00Si
Oct 29, 2008 10:09 AM
kartman
15
Jul 19, 2007 09:51 PM
integra6650
Jun 5, 2003 06:44 PM
