Low PSI BOV - 4 PSI?
Ill be running 4 lbs for now, dont tell me how i need to up the boost, i already know that, but for now, this is the only way.
-Moving on, I have a TurboXS RFL just waiting to go on... now someone said something about removing the washers in it so it would blow off? Since its rated at 8 or 10 PSI. So could that work, or what other BOV could I use with that low of PSI... (besides the whistling GReddy Type S, i hate those, i REALLY dis-like those whistling type)... fludder bov's i do like though
let me know!
-Ryan
let me know!-Ryan
Your gonna need around 8 to have the RFL work even with all the washers removed. Best bet is prob get the small hks BOV if you do not want the type-s . WHy are you only going to run 4psi?
my RFL was crazy loud with my 3-4 psi wastegate then when it got turned up to 10 it was even louder. it would pop off just reading 0psi under load. I had 2 washers installed.
lol
