WTF Idleing like crazy???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">Have you checked your IACV and/or TPS?</TD></TR></TABLE>
could it be those? Be cause when i hook the obd2 ecu back on then it runs totally fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proglow3 »</TD></TR><TR><TD CLASS="quote">Check to make sure you don't have a vacuum leak.</TD></TR></TABLE>
Go away, you are a ******* moron.
Check your IACV.
Check your IACV.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Go away, you are a ******* moron.
Check your IACV.</TD></TR></TABLE>
I don't think it would be the IACV because it runs fine with the other ECU.
What motor is in the car now and what OBD-1 ECU are you using to run it? Is the ECU already socketed/running a bin file or are you running off of the stock ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">I don't think it would be the IACV because it runs fine with the other ECU.
What motor is in the car now and what OBD-1 ECU are you using to run it? Is the ECU already socketed/running a bin file or are you running off of the stock ECU?</TD></TR></TABLE>
running a 96 gsr motor in a 97 ek. Ran with a stock 92-93 gsr ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhard_si »</TD></TR><TR><TD CLASS="quote">its the wire harness because it happen to me....check the top n back plugs from the manifold....good luck n update
what exactly am I looking for? What was wrong with yours?
</TD></TR></TABLE>what exactly am I looking for? What was wrong with yours?
