CV joint problems!
Old Aug 14, 2005 | 08:27 PM
BigDawwg6969's Avatar
Default CV joint problems!
Alright.... im in the process of removing my cv joints so i can drop my transmission... the problem is that the cv joint is stuck in the hub and WILL NOT COME OUT!!!!!!!! anyone have this problem before? any help would be appreciated! BTW... its for the 4 spd tranny
Old Aug 14, 2005 | 09:36 PM
RCautoworks's Avatar
Default Re: CV joint problems! (BigDawwg6969)
You try a pry bar ? Just keep trying, I have seen some that really get stuck in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Little &raquo;</TD></TR><TR><TD CLASS="quote">
You cannnnnnnnnnn do it.</TD></TR></TABLE>
Old Aug 15, 2005 | 12:05 AM
91civicEX's Avatar
hit it with a hammer. the bigger the better
Old Aug 15, 2005 | 02:42 AM
Default Re: CV joint problems! (91civicEX)
yeah... but i don't wanna mash down the shaft too much! and there isn't enough room to get a pry bar in there.....this sucks!
Old Aug 15, 2005 | 09:41 AM
bump for ideas!!!!!!!!!!!!!!
Old Aug 15, 2005 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 &raquo;</TD></TR><TR><TD CLASS="quote">yeah... but i don't wanna mash down the shaft too much! and there isn't enough room to get a pry bar in there.....this sucks! </TD></TR></TABLE>
Go buy another pry bar then, thats the only way you are gonna get it out then. You won't mash it at all, if you pry it between the cv joint and the transmission.
Old Aug 15, 2005 | 09:53 AM
Default Re: CV joint problems! (90blackcrx)
not stuck in the tranny.... it's stuck in the hub
Old Aug 15, 2005 | 09:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 &raquo;</TD></TR><TR><TD CLASS="quote">not stuck in the tranny.... it's stuck in the hub</TD></TR></TABLE>
Oh, take a punch and tap the end, buy some pb blaster and spray it on there. Usuually the punch will work though, hit it with a 5lb sledge, don't worry axles are strong enough
Old Aug 15, 2005 | 10:13 AM
alright... ill try it out tonite after i get off of work! thanks!
Old Aug 15, 2005 | 01:01 PM
Also don't be affraid to pound on the knuckle, vibration will break the rust and the axle will come out easier, just don't pound on the rotor or anything else that will break.
Old Aug 15, 2005 | 06:12 PM
EJ2-Fluffy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Also don't be affraid to pound on the knuckle, vibration will break the rust and the axle will come out easier, just don't pound on the rotor or anything else that will break.</TD></TR></TABLE>
Or you can use a puller on it. Thats what I did. Came out like a charm
-Jon
Endo-land
Sep 8, 2007 10:43 AM
dleccord
Jul 9, 2007 03:05 AM
siguy4
May 13, 2006 05:23 PM
Andyb22g
Jul 15, 2004 10:01 PM
InfamousGSR
Apr 16, 2004 10:17 AM
