auto to manual...
Old Aug 14, 2005 | 03:55 PM
honda95civic's Avatar
Default auto to manual...
whats the easiest way to get the pedal assem. out so i can bolt on the manual pedals...
the steering column is in the way.. should i just shimmy it till it comes out.. dont want to cut anything
Old Aug 14, 2005 | 10:02 PM
Default Re: auto to manual... (honda95civic)
bump... how do i get these pedals out... 95 civic auto.. not for long..
Old Aug 15, 2005 | 07:32 AM
bgibson99's Avatar
if you are talking about the brake pedal, which I assume you are since the steering column is in the way, then you should only have to remove the spring on the pedal and the bolt that holds it in. I don't think you need the entire assembly, just the pedal. Atleast on my 92 accord I didn't need the whole assembly.
-Brian
Old Aug 15, 2005 | 11:50 AM
stealthmode62's Avatar
Default Re: auto to manual... (bgibson99)
Leave the gas pedal alone. Swap only the arm on the brake pedal as mentioned above. Then put the clutch pedal in which is a whole seperate assembly.
Old Aug 15, 2005 | 10:15 PM
Default Re: auto to manual... (stealthmode62)
thanks ..
grandtheftlunchbox
18
Sep 3, 2008 07:37 PM
CustomX113
Jul 17, 2006 02:01 PM
nimblecivic
28
Aug 30, 2004 03:12 PM
oneslodx
Aug 20, 2004 06:50 AM
crx_91si
May 23, 2004 01:22 PM
