positive camber problem - 2000 dx front spindles
Old Aug 14, 2005 | 01:03 PM
AllMotorMark's Avatar
Default positive camber problem - 2000 dx front spindles
is there an upper control arm that is shorter that will bring my camber in?
the tires a way positive on the camber....i used 2000 civic dx spindles cause the old ones were trashed and these where free....
Old Aug 14, 2005 | 01:48 PM
EL Vap133's Avatar
Default Re: positive camber problem - 2000 dx front spindles (AllMotorMark)
I think the spindles are the problem. What upper arm did you use on them spindles?
Old Aug 14, 2005 | 02:25 PM
Default Re: positive camber problem - 2000 dx front spindles (EL Vap133)
i know they are i used the 88 crx ones, is there upper control arms witch are shorter?
Old Aug 17, 2005 | 07:20 AM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMark &raquo;</TD></TR><TR><TD CLASS="quote">i know they are i used the 88 crx ones, is there upper control arms witch are shorter?</TD></TR></TABLE>
i would like to know as well. i have a cheap spc camber kit with 92-5 knuckles(the 88-91 would not clear my slicks) and i cant get enough negative camber, im at +2.7degrees right now. im told the 92-5 uca will not bolt up but i have not confirmed this.
ChevelleSSLS6
Mar 10, 2009 01:05 PM
6doorsentra
19
Jul 10, 2007 11:11 AM
civicgeek133
Suspension & Brakes
12
Nov 26, 2006 06:40 PM
Backk InTheDA
Jul 17, 2006 03:38 AM
89civicdx
Apr 22, 2003 12:07 PM
