throwing crazy codes
Old Aug 14, 2005 | 10:22 AM
cashman38's Avatar
Default throwing crazy codes
I just put a b18b in my car but used all my obd-o parts,intake,dizzy all that.The car is throwing codes 4,5,6,7,and 9. Also it won't go past 3500 and its hiting some kind of rev limit. Please help.
Old Aug 14, 2005 | 10:30 AM
komat's Avatar
Default Re: throwing crazy codes (cashman38)
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
9 CYP - cylinder sensor
you are in limb mode
get the cel fix then u be able to go pass 3500
Old Aug 14, 2005 | 06:50 PM
cashman38's Avatar
Default Re: throwing crazy codes (komat)
I changed the dizzy and the computer but its still doing it. I bought a new throttle body withj the tps sensor. I'm going to change that and see if thats it, if not what should I do next?
Old Aug 14, 2005 | 09:43 PM
boostedcivic805's Avatar
your wiring is jacked up The Tps and map try switching the 2 plugs, as for codes 9 and 4 you need to check your wiring at the ecu there is a ORANGE and a WHITE wire that need to be moved from c1 and c2 to b10(orange) b12 (white)and the 2 blue wires go to c1(blue/green) c2(blue/yellow) check that that is all correct. and the code 6 check the plug under the Dizzy that single wire always breaks. hope this helps.
Old Aug 14, 2005 | 09:48 PM
RCautoworks's Avatar
Yep, the wiring is all messed up. Or your alternator could be dead, bad alternators will make some weird things happen.
Old Aug 14, 2005 | 09:56 PM
91civicEX's Avatar
Default Re: throwing crazy codes (90blackcrx)
yea check ur wiring before u start replacing parts.
Old Aug 15, 2005 | 09:04 AM
cashman38's Avatar
Default Re: throwing crazy codes (91civicEX)
I did all the wiring when I put the b18a in and it fired right up and ran fine. Then I blew that motor up and installed the b18b and thats when I started having these codes. I know I bumped the map sensor when I put the new motor in but I don't know if thats the problem.
jus_spooln_wicha
Jun 13, 2007 12:04 PM
grizzy225
Feb 22, 2007 09:03 AM
H22A EG6
Feb 29, 2004 01:20 PM
Leisyman
May 6, 2003 09:35 AM
97hb
Mar 23, 2002 03:00 PM
