Turbo Coolant Lines Idea
So i got a new radiator that has the two extra fittings for what i guess is the Automatic Tranny cooler (?)
They are both on the radiator but can i run my turbo coolant feed/return two the fittings and be okay???
thats not going to work....the coolant flows in a direction IN the turbo then OUT. If you hook both of them up to that it's not gonna flow anywhere. Use the lines from your throttle body, you get a cooler TB and the lines are already there. good question though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi »</TD></TR><TR><TD CLASS="quote">ATF is pumped in and out by the turbine inside the transmission. If you use the TB lines they are already set up to flow.</TD></TR></TABLE>
i had no idea
anything i can use those ports for or just block them off?
i had no idea
bambam
Apr 13, 2005 02:21 PM
