Suspension & Brakes Theory, alignment, spring rates....
extended wheel studs
Old Aug 13, 2005 | 11:18 AM
BLUE EH3's Avatar
Help we my pennies
Default extended wheel studs
what are they for?
Old Aug 13, 2005 | 11:24 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: extended wheel studs (BLUE EH3)
i am plannin on gettin drags also
Old Aug 13, 2005 | 04:10 PM
ohjolt2's Avatar
so you can run wheels with thick hubs, you can use spacers, you can use them long *** lug nuts and have plenty of thread. That good enought?
Old Aug 13, 2005 | 04:24 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (ohjolt2)
what r u spaces for? wider traction?
Old Sep 7, 2005 | 12:41 PM
Fitti's Avatar
Spacers are used when you need to space the rim out so that it will clear the caliper.
cars with bigger brakes like the integra can't use 13in rims for slicks unless that have a spacer.
Old Sep 7, 2005 | 08:36 PM
blaqman's Avatar
Default Re: (Fitti)
for that super stunna jdm look son(DUH!) j/k. I agree, they primarily for drag racing cause they use spacers on some of the wheels. On my car I just like em cuz they make the wheel easier to put on when im workin on it. Kinda stoopid but so wut!
Old Oct 3, 2005 | 07:38 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (blaqman)
CAN u use wheel locks?
Old Oct 3, 2005 | 08:03 PM
slammed_93_hatch's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">CAN u use wheel locks?</TD></TR></TABLE>
no
Old Oct 3, 2005 | 11:14 PM
yoshi_1r671's Avatar
if you get extended studs, i think you need 50 size lugnuts if you want to cover it
Old Oct 4, 2005 | 08:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">what r u spaces for? wider traction?</TD></TR></TABLE>
h0lla!!!
lol......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi1rky &raquo;</TD></TR><TR><TD CLASS="quote">if you get extended studs, i think you need 50 size lugnuts if you want to cover it</TD></TR></TABLE>
wtf are you talking about?
The extended studs arent necessarily for spacers. I bought them because they are stronger than the OEM studs and very hard to damage, and makes the lugs easier to get on.
Old Oct 4, 2005 | 08:42 AM
JDogg's Avatar
Default Re: (.RJ)
which extended lugs do you guys run.. i have a couple that need replacing.. may as well spend the $ and put some good stuff in there.
Old Oct 4, 2005 | 08:45 AM
DC4_MADMAN's Avatar
Wheel spacers can shear extended studs.
I use Skunk2 studs on all 4 corners.
.RJ's Avatar
.RJ
Default Re: (JDogg)
ARP is the only way to go.
Old Oct 4, 2005 | 08:59 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (4door_demon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">Wheel spacers can shear extended studs.</TD></TR></TABLE>
WTF are you talking about? How would that even be possible?
Old Oct 4, 2005 | 09:02 AM
.RJ's Avatar
.RJ
Wrong.
Old Oct 4, 2005 | 09:06 AM
DC4_MADMAN's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong.</TD></TR></TABLE>
NOT wrong. Seen it happen with ARPs on a Mustang.
Old Oct 4, 2005 | 09:12 AM
.RJ's Avatar
.RJ
NOT wrong. Seen it happen with ARPs on a Mustang. </TD></TR></TABLE>
Under what circumstances? Improperly torqued lugs will shear studs off too. You cant take an isolated incident, sprinkle a little urban myth and present it as fact.
Old Oct 4, 2005 | 09:19 AM
DC4_MADMAN's Avatar
Default Re: (.RJ)
Under what circumstances? Improperly torqued lugs will shear studs off too. You cant take an isolated incident, sprinkle a little urban myth and present it as fact.</TD></TR></TABLE>
Edit: Nevermind, it doesnt make sense now that I think on it. These guys were probably trying to cover their stupidity of not torqueing the lugnuts..
I retract the statement.
Old Oct 4, 2005 | 09:32 AM
JDogg's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">ARP is the only way to go.</TD></TR></TABLE>
for some reason i remember seeing some thing about arp studs not fitting the hubs properly??
Old Oct 4, 2005 | 09:34 AM
Suspetise...
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">for some reason i remember seeing some thing about arp studs not fitting the hubs properly??</TD></TR></TABLE>
Nope. I just put some in my hubs two days ago and they fit fine. If you buy the wrong ones, sure they won't fit properly.
MugenEg
Dec 28, 2009 12:21 PM
gakkuken
21
Jan 10, 2005 02:28 PM
BoOsTiN Dc2
Aug 31, 2004 02:45 PM
sjteg
Dec 20, 2003 09:09 AM
Hexxboy
Audio / Security / Video
Apr 30, 2002 01:50 PM
