Exhaust blowing out oil
Old Aug 13, 2005 | 11:01 AM
1bar_ek's Avatar
Default Exhaust blowing out oil
I just recently changed my turbo. Went from the t3/to4b to the t3/to4e turbo. After changing the turbo, and turning on the engine, I realized a lot of smoke coming out from my exhaust system. I revved my car a few times, and some oil starts to shoot out.
Anybody know what's wrong??!!??
Engine has been rebuilt, and only has 500 miles on it.
Old Aug 13, 2005 | 11:03 AM
B20TDC2's Avatar
Default Re: Exhaust blowing out oil (darkside_ek)
was the turbo new? sounds like the seals are bad on your exh. side if your losing that much oil
Old Aug 13, 2005 | 11:06 AM
1bar_ek's Avatar
Default Re: Exhaust blowing out oil (B20TDC2)
Yes, turbo was new. Yeah, I haven't changed my seals yet, just ordered some, so currently just waiting for them to arrive.
1bar_ek's Avatar
anybody else?
Old Aug 13, 2005 | 11:10 AM
pushinlsteg's Avatar
well... since you said the only thing you changed was the turbo. I'm gonna have to say that there seems like there is a seal problem somewhere with the turbo...
otherwise if its not the turbo, bye bye rings, or bye bye valve seals or something of the sort.
Old Aug 13, 2005 | 11:14 AM
1bar_ek's Avatar
Default Re: Exhaust blowing out oil (pushinlsteg)
New rings came along with the je pistons. New valve seals, because i just got my head fully built with new skunk2 valvetrain and new stock oem valve seals.
Daily driven at 6 lbs of boost.
Old Aug 13, 2005 | 11:22 AM
B20TDC2's Avatar
more han likely its your turbo seals . check them and let us know
Old Aug 13, 2005 | 12:06 PM
1bar_ek's Avatar
Thanks. Will go back to WI to check my car. Will let you know.
Old Aug 14, 2005 | 09:26 AM
1bar_ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">more han likely its your turbo seals . check them and let us know</TD></TR></TABLE>
I would need to get the turbine shaft seal right, or the compressor seal??
rich7777
Nov 30, 2014 05:15 PM
1FastLS
Mar 31, 2006 04:33 PM
j-robsDA
Aug 2, 2005 08:04 AM
Rob!
Dec 18, 2004 03:08 PM
E-Rok
Dec 19, 2002 08:14 PM
