timing belt slack?
Old Aug 13, 2005 | 09:31 AM
an2ny888's Avatar
Default timing belt slack?
how much play should the timing belt have on the long side (exhaust cam )? i was looking at it with the motor idling and i could see it flapping a bit. should it be really tight when i push on it or is a little play normal?
Old Aug 13, 2005 | 03:43 PM
C-speed's Avatar
Default Re: timing belt slack? (an2ny888)
http://www.c-speedracing.com/h...2.php
Old Aug 13, 2005 | 03:46 PM
Bbasso's Avatar
Your search for timing belt returned 26 results.
Old Aug 13, 2005 | 08:27 PM
an2ny888's Avatar
Default Re: timing belt slack? (Bbasso)
i searched before posting this. what i need to know is should the long side of the tb be really tight, as tight as the belt between the cam gears? or should there be an inch of play, like it says on the cspeed site
Old Aug 14, 2005 | 01:31 AM
an2ny888's Avatar
just went out and retightened it according to helms, still flaps around. should both sides of the belt have the same slack? when i look at the intake side it doesnt move around at all, should the exhaust side be this tight as well?
Old Aug 14, 2005 | 06:02 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">when i look at the intake side it doesnt move around at all, should the exhaust side be this tight as well?</TD></TR></TABLE>
yes.
i like to put the same amount of tension on all three sides of the belt.....
(little to zero deflection)
-t3h r0cker, who has been through many set of toda cams with favorable results.
pkdog167
Nov 10, 2009 10:29 PM
B18C5_VTEC
10
Nov 7, 2007 04:04 PM
boosted ek
11
Feb 12, 2005 06:55 PM
JDMlyfestyle
Nov 24, 2004 04:48 PM
