HELP! B16 89 CRX Engine trouble
Old Aug 12, 2005 | 07:06 PM
proskater's Avatar
Default HELP! B16 89 CRX Engine trouble
One second my car was idling really nice and then it slowly died on me. Now when I crank it it barely turns over and if I put my foot on the floor it will hardly rev up. The car shakes and it sounds really bad and if I keep it running with my foot on the gas it starts to misfire out the intake. I kept the car running just to look at the code and I believe it was 54. Any help?
Old Aug 12, 2005 | 07:34 PM
SixguN's Avatar
Default Re: HELP! B16 89 CRX Engine trouble (proskater)
54 is your crank fluctuation sensor. Check to see if its hooked up or see if its bad. I don't know if it will trigger a cel if its not hooked up but give it a try.
Old Aug 13, 2005 | 08:21 PM
proskater's Avatar
Default Re: HELP! B16 89 CRX Engine trouble (Sixgundone)
My car was running fine and then the B+ cable to the starter solenoid grounded out on the starter motor and there were some sparks. I checked my fuses and they are all good. I just bought a spark tester and fuel pressure gauge, so tomorrow I will begin diagnosing what may be wrong. Ugh, I'm just so tired of fixing something and having another thing break RIGHT AWAY.
Old Aug 14, 2005 | 06:00 PM
proskater's Avatar
Performed a spark test and saw that I had no spark on a couple of cylinders but good ones on the other two. So I took apart the distributor and found out that I could easily pull off the rotor! Apparently I didn't put loctite on the screw to hold the rotor in place and it just backed off. However, while the cap was off I saw that a screw was missing to hold a piece of wiring down, which looked like a ground point. Now I have to find a really small *** screw to put in there or I'm going to have to get a new distributor.
t_ank
28
Aug 22, 2010 12:12 PM
phillyk89
Oct 2, 2009 08:07 PM
TegProject
Mar 4, 2007 06:28 PM
jdm_racer831
Nov 21, 2006 11:56 AM
South Bay Surfer
Jan 25, 2004 03:44 AM
