Proportionning valve help
Old Aug 12, 2005 | 04:44 PM
Garrett's Avatar
Default Proportionning valve help
My civic 90 SI had rear disk brake 9.5" with HP+ pads
the front his 11" Corrado Disk with integra caliper and HP+ pads
I need more power for the rear brakes
the actual Proportionng Valve 3540 (I don't know if if OEM or not because my DX 91 had a 2530 PV)
Old Aug 14, 2005 | 05:32 PM
Garrett's Avatar
Default Re: Proportionning valve help (Garrett)
nobody know which one I should use?
Old Aug 14, 2005 | 05:43 PM
Putput's Avatar
3540 isn't the stock valve on the civic. 3540 is usually screen on the 88-89 integra, and some early preludes. Both these cars have 4 wheel disc. I personally use the one from the 90-93 integra which is labed at 4040. I don't know if it there is difference, but I figured that's my rear is off an 90-93 integra, and my booster and Master cylinder is from an 90-93 integra, I'd use the same.
Old Aug 14, 2005 | 05:46 PM
Garrett's Avatar
Default Re: Proportionning valve help (Putput)
the fact are that actually I have too much power on the front
soo I want more pressure on the rear brakes
but it's hard to find the good PV
Old Aug 14, 2005 | 06:03 PM
Tyson's Avatar
go 4040.
3540 also came with 90-91 EX with larger front discs and drums in the rear.
although, its never a good situtation to have your rears lock up before your fronts. i wouldnt try to achieve that.
gotgrip_st185
Suspension & Brakes
May 7, 2015 12:13 AM
BmoreCivic
Jul 2, 2006 04:59 PM
SAVIOVEGA
Aug 16, 2005 07:57 PM
Discosteak
Apr 22, 2005 01:37 PM
