Starter Assembly blowing off of mount on motor???
Old Aug 12, 2005 | 02:54 PM
EnjoyTheRideDC2's Avatar
Default Starter Assembly blowing off of mount on motor???
Just curious, has anyone had their starter break or blow off of their motors? A friend of mine said it has happened to him and I find it unbelievable for a starter to blow right off.
The story I heard was one afternoon, he went to get gas and once finished filling his tank, he tried to start up his car. All he heard were a series of clicks, possibly those similar to the ones you hear when your battery goes weak. Then, After repeated tries at starting the car, he suddenly hears a whinning sound, constant with the turn on the key to the start position. Opens up the hood, finds the starter dislodged from where it should be bolted in.
If it is possible for this to happen, what would cause such a thing?
Old Aug 12, 2005 | 02:59 PM
BolivianDc2's Avatar
Default Re: Starter Assembly blowing off of mount on motor??? (EnjoyTheRideDC2)
maybe he didnt tighten down the 2 14mm bolts holding it down
Old Aug 12, 2005 | 03:10 PM
Default Re: Starter Assembly blowing off of mount on motor??? (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">maybe he didnt tighten down the 2 14mm bolts holding it down</TD></TR></TABLE>
Well, the Dealer replaced the starter over 2 years ago. It had been starting up without a problem until that day. I kind of deleted that idea from possible reasons for that to happen.
Old Aug 12, 2005 | 11:35 PM
Any other suggestions?
Old Aug 13, 2005 | 03:38 AM
Duane_in_Japan's Avatar
It is bolted into aluminum, eassy to strip the threads?????????
Old Aug 13, 2005 | 04:31 AM
Default Re: Starter Assembly blowing off of mount on motor??? (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">It is bolted into aluminum, eassy to strip the threads?????????</TD></TR></TABLE>
True, but if that was the case, why would the problem occur over 2 years after it was initially replaced? It took 2 years time for a bolt to back out or fall out from its stripped hole and loosened the starter enough to blow out of its place?
Old Aug 13, 2005 | 04:49 AM
jthm's Avatar
The bolts were not torqued properly and after years of vibration they loosened themselves enough for the starter to pop out.
Old Aug 13, 2005 | 06:19 AM
Default Re: Starter Assembly blowing off of mount on motor??? (squee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squee &raquo;</TD></TR><TR><TD CLASS="quote">The bolts were not torqued properly and after years of vibration they loosened themselves enough for the starter to pop out.</TD></TR></TABLE>
Is this really possible?
Old Aug 13, 2005 | 07:23 AM
jthm's Avatar
It happend to my car once. The bolt was barely loose and after enough time had passed there was enough slack for the starter to jump and start skipping on the flywheel.
azandford
Apr 29, 2010 06:03 AM
gtowni3
Sep 29, 2004 01:20 PM
ghost_ryder35
Mar 19, 2004 10:51 AM
00fbp
Jul 15, 2003 07:30 PM
Chairman Kaga
Oct 28, 2002 04:23 PM
