Transmission clank
I've got a 94 Accord EX 5-speed with 90K that I bought used. Sometimes (and more often recently) it is hard to get the gear to go all the way into reverse, and it will sometimes make a loud short clanking sound when it does. Other gears get difficult sometimes, like I have to force/wiggle it more than shift smooth, but the noise is only in reverse. The clutch is all the way in of course.
What could this be? Annoyance, or am I shifting with a time bomb? The clutch is beginning to show minor signs of slippage in first, but it's no too bad and I'd rather wait to replace it since I'm broke- would that help at all or no? I haven't flushed the tranny fluid since I got it, and the level was fine last time I checked. Thanks.
No grinding, although first is starting to slip when I go uphill or something. I only hear the loud metallic clanking noise when shifting from a stop to reverse. Sometimes first or second or reverse will be difficult to get all the way into position, like I have to force it the last inch or so, but no noise.
Will a typical clutch replacement fix my problems? I'd rather not invest much more than that in this car. I was going to do the timing belt soon, but if it's going to be timing belt and complete tranny, then I may have to let her go.
So in neutral it will clank also huh? I kno for sure my clutch is going out cuz its slippin and i have to force reverse that last inch like you. But the only clank noise I hear is when i pop it in reverse that last inch. But it could be something else.
No, the clank is only from neutral to reverse. I guess my main question is will a clutch replacement fix my problem, or is there something morre serious with my gears?
