91 5-speed winding noise...
Old Aug 12, 2005 | 10:11 AM
i20ar's Avatar
Default 91 5-speed winding noise...
hey guys i need your help...
yesterday my friend came into work with his 91 5-speed (i think its lx)... and when he was comming into the parking lot i heard this really bad winding noise... so i as ked him what happend and he said he was racing sum1 and when he shifted into 3rd.. all of a sudden he started hearing that winding noise... even since then it wont go away im sorry if its not a great discription but its all i got the hear from him and i didnt have much time to check it out... but i told him to pop the hood to see where the problems from and it sounded like all teh noise is comming from here....
sorry i dont know what that part is called so can sumone enlighten me...
that was the best pic i could find sorry
this a pic of my motor.. but its has the same part just in a differnt location
Modified by Dj14aZnS at 11:21 AM 8/12/2005
Old Aug 12, 2005 | 10:24 AM
i20ar's Avatar
Default Re: 91 5-speed winding noise... (Dj14aZnS)
i think it has to to with his throttle but what.. i have never learned what that part is for... for a better description of what the sound is it sounds like a r/c car.. or an alectric motor sound..
Old Aug 12, 2005 | 10:59 AM
93.2's Avatar
well..... the part your circled is the cruise control.... but i dont' see why that would make a winding noise...
Old Aug 12, 2005 | 11:10 AM
i20ar's Avatar
Default Re: 91 5-speed winding noise... (g-wagon)
O ok.. hmm maybe its not that then it sounded like thats what it was.... well can any1 think of what else it might be..? it just a really lound winding noise..
Old Aug 12, 2005 | 01:12 PM
i20ar's Avatar
any1?
Old Aug 12, 2005 | 01:21 PM
fw190bvi's Avatar
mp sure what, but your friend doesnt have a 91. that is a 3rd gen accord....that motor is an EFI A20....
Old Aug 12, 2005 | 06:11 PM
typhoon's Avatar
Default Re: 91 5-speed winding noise... (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">mp sure what, but your friend doesnt have a 91. that is a 3rd gen accord....that motor is an EFI A20....</TD></TR></TABLE>
Yeah, that is def not an f22a. It's prob a 3rd gen LXi
Old Aug 12, 2005 | 10:12 PM
i20ar's Avatar
Default Re: 91 5-speed winding noise... (typhoon)
oh yea... sorry guys.. it was the closest pic i could find.. the engine laout is the same... as the f22a is isnt it..? the reason i used that pic was becauses the sound we were hearing was coming from that area... so any other have any ideas..?
Old Aug 13, 2005 | 12:32 PM
i20ar's Avatar
bump....
Old Aug 13, 2005 | 08:05 PM
soon2bdropped's Avatar
is it me or thats an engine of an 86-89 acccord?
Old Aug 13, 2005 | 09:30 PM
carracr625's Avatar
Default Re: 91 5-speed winding noise... (soon2bdropped)
Eventhough your pics aren't clear as to what area of the engine bay you are reffering to. Have you eliminated a worn or loose belt? I have heard a similar noise when my belt was slipping on my civic.
Old Aug 13, 2005 | 10:08 PM
i20ar's Avatar
Default Re: 91 5-speed winding noise... (carracr625)
IVE SAID THAT THAT WAS THE CLOSEST PIC I CAN FIND TO THE ENGINE SET UP... YES THAT IS NOT AN F22A BUT ITS LAYOUT IS THE SAME... THE NOISE IS COMMING FROM THAT CIRCLED AREA in the A20....the lower rigth side area
ive heard belts slipping before those sound more of a high pitch sqealing noise... this noies that i heard was almost the sound like a RC cars motor ... and it made teh sound at idle at all times... the faster he went the louder it got..
Old Aug 14, 2005 | 07:38 AM
deserthonda's Avatar
it could be ur alternator,? ,,,,,,,,,,, ur water pump,? ,,,,,,,,,,,,,,,,, remove the altern belt and start car up if noise still there that will eliminate altern
Old Aug 14, 2005 | 08:30 AM
i20ar's Avatar
Default Re: 91 5-speed winding noise... (deserthonda)
its posible to run without an alternator? i thought the car would die.. but thats sounds like a good idea to try.. the wierd thing is that it only started to do this when he shifted to third that night.. but i gues that this was going to hapen sooner or later.. how har is it to put the belt back on once we have it off? is it a matter of popping it off or is it to tight for that ?
hmm a water pump? does it spin also... what ever is making this sound spins becuase when he gives it gas in neutral.. the more the rpms rise the louder and faster revving the sound it gets
Old Aug 14, 2005 | 08:37 AM
i did not say run it without an alternator belt i said remove belt and start engine see if noise goes away ,,,it is just for a diagnostic purpose ,,no u cannot leave alt belt off and drive car for a long time it will die '
as for removing the alt belt. loosen up both upper and lowrr alt bolts. then from the front there is a 10mm bolts that is the adjuster bolt go counterclock wise to reduce belt tension remove belt when loose enough,,,,,,,do not unscrew adjuster bolt totally it might be a little pain to put back in so just do it enough to be able to slip belt off ........
and yes the water pump spins anythime engine is running it is driven by the timing belt
Old Aug 14, 2005 | 10:49 AM
i20ar's Avatar
oh ok i'll try that thanx.. i didnt know the car would even start with the alternator taken off..i wasnt planning on tell him to drive it... but i thought the car would just start and die shortly after... is there anyway to diagnos the water pump..?
rsa0905
Oct 29, 2009 05:09 PM
Bobhonkey
Oct 8, 2009 05:56 PM
tegda
May 6, 2007 08:12 AM
r0ckingrrl
Jan 24, 2005 03:58 PM
