Replaced Head Gasket, and Still have a leak
Old Aug 12, 2005 | 10:10 AM
BigBoulda's Avatar
Default Replaced Head Gasket, and Still have a leak
Hello out there.
I noticed a while ago, that there was a small dribble of oil between my head and block on the front corner on the distributor side of the motor. I assumed that it was the head gasket, so I ordered a new Buddy Club gasket, and a set of ARP head studs.
We took the head off (it was a bitch), cleaned everything off, and got all the oil off the head/block surfaces. Then we put the new studs into the block (using the ARP lube), put the new gasket on, and then put the head on, and tightened everything back to factory torque specs. After resetting the timing and valve lash, I started the motor, but the timing belt jumped a tooth, so I had to redo the timing, and it worked fine and ran fine.
But, there is still the same slight dribble of oil coming from the same spot between the block and head. It is a very slow leak (I only have to add a very small amount of oil every week or so. Maybe 1/4 quart over a month), but it is driving me nuts, especially since I spent a few hundred dollars and a full day replacing the head gasket. What could it be?
Old Aug 12, 2005 | 05:05 PM
builthatch's Avatar
MiG-21 superfan
Default Re: Replaced Head Gasket, and Still have a leak (BigBoulda)
cam seal.
Old Aug 12, 2005 | 10:07 PM
PURPLETERROR aka BIGMATT's Avatar
cam seal
Old Aug 12, 2005 | 11:13 PM
snowseeker's Avatar
Default Re: Replaced Head Gasket, and Still have a leak (PURPLETERROR)
Or Vtec seal. Yes they do leak sometimes.
Old Aug 13, 2005 | 05:50 PM
mportbusta's Avatar
cam seal
Old Aug 18, 2005 | 10:15 PM
MantisX's Avatar
Default Re: Replaced Head Gasket, and Still have a leak (mportbusta)
Will a cam seal allow coolant into the combustion chamber like a blown head gasket will? I have an oil leak near the bottom part of my engine, right under the cam gears.
MantisX
Old Aug 19, 2005 | 04:35 AM
builthatch's Avatar
MiG-21 superfan
Default Re: Replaced Head Gasket, and Still have a leak (MantisX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MantisX &raquo;</TD></TR><TR><TD CLASS="quote">Will a cam seal allow coolant into the combustion chamber like a blown head gasket will?
MantisX</TD></TR></TABLE>
no. the cam seal is on the dist. side of the exhaust cam and solely acts as an oil stop.. the OE hard plastic ones fatigue and leak oil; there are many billet options out there to replace this part.
Old Aug 19, 2005 | 04:41 AM
GSlowR's Avatar
if it's not what everyone mentioned you'll need to have your head taken to a machine shop.. i don't know the terminology but what they do is flatten the bottom..
Old Aug 19, 2005 | 08:48 AM
9341civic's Avatar
Default Re: Replaced Head Gasket, and Still have a leak (GSlowR)
its called milled
Old Aug 19, 2005 | 09:43 AM
builthatch's Avatar
MiG-21 superfan
Default Re: Replaced Head Gasket, and Still have a leak (9341civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9341civic &raquo;</TD></TR><TR><TD CLASS="quote">
its called milled
or surfaced
protopro88
Jun 17, 2011 02:17 PM
2-logicl
Mar 27, 2006 07:04 PM
MNturbosi
Apr 9, 2004 04:57 PM
R6Elmo
Nov 13, 2003 04:47 PM
