3400 RPM rev Limit??? Help
i just did a b16 swap into my crx and its all wired up and starts but it cuts out at 3400 rpm ive changed the dizzy and the fuel pump and fuel filter i believe everything is wired up properly otherwise the car wouldnt start and run im running a Pr3 im getting a code 4 and 6 with the new dizzy on i need some help any advise will do
nope, the tps's are the same..but may not be working..or might need an adjustment. recheck the wiring..and again..make sure your grounds are good..make sure you recheck the one from the ecu to the thermostat housing.
jonny
jonny
"the dizzy is brand new so how could it have a bad crank sensor isnt that where the cranksensor is located anyway on these engines..."
Had that problem when i swapped in a ZC, i had a "brand new" dizzy, but wouldn't rev past 3400. learned a lesson that day a "brand new" dizzy isnt "brand new" unless you buy it from a dealer, dizzys from kragen are NOT brand new and ALWAYS have problems. so i went to a junk yard and picked up a stock dizzy (make sure to ask them if its the orginal dizzy) put it in my car and it worked fine.
i had the same problem. i built a b18 motor and the thermostat housing was a little messed up. the ground wire that goes there sucked so i relocated the wire to a different place and the car reved great. it is important to check all your ground wires, make sure you disconnect the batery.
csunny95
Sep 20, 2018 10:15 AM
Carbcivic
11
Oct 11, 2007 05:45 PM
