battery relocation - fuse or circuit breaker rating
Old Aug 12, 2005 | 12:33 AM
7808's Avatar
Default battery relocation - fuse or circuit breaker rating
i re-located my battery to my trunk to make room for charge pipe and put my yellow top in there, but i got staight 4gauge to the batt from my dist. block under the hood. i've been told i should use a fuse or circuit breaker by the battery which just kinda makes sense anyways
what size fuse or circuit breaker should i use? im assuming engine cranking would blow most of the car audio fuses i have around (30A-60A), and i'd rather just get a breaker incase a fuse would blow and i dont have another on me.
Old Aug 12, 2005 | 09:06 AM
drdisco69's Avatar
Default Re: battery relocation - fuse or circuit breaker rating (7808)
I don't think 4 gauge is heavy enough... Does it crank ok or a little slow?
Old Aug 12, 2005 | 12:00 PM
7808's Avatar
Default Re: battery relocation - fuse or circuit breaker rating (drdisco69)
it cranks normal. actually a little faster with the optima
Old Aug 12, 2005 | 12:01 PM
skr33t_rac3r's Avatar
4 gauge is prolly enuff cause thats wut ive been using for a while now
Old Aug 12, 2005 | 07:51 PM
7808's Avatar
Default Re: (skr33t_rac3r)
so can anyone answer my question?
Old Aug 12, 2005 | 09:36 PM
IO_303's Avatar
On mine i am using a 100a and have had no problems.
its a fuse block like this one
http://www.cardomain.com/item/STISFB1MAX
EFinawesomeman
Dec 31, 2012 09:34 AM
mtg
Nov 29, 2009 07:44 AM
DarkBB4
Jun 13, 2007 10:19 AM
hu
Audio / Security / Video
12
Aug 3, 2006 02:38 PM
silverCRXTC
Jan 8, 2004 04:57 PM
