sohc head removal question
Old Aug 11, 2005 | 07:39 PM
Copy Cat's Avatar
Default sohc head removal question
I have worked on dohc vtec motors but not sohc motors. im replacing the head gasket on my sisters car, and is it really necessary to remove the cam, dist and the rocker arm assembly to remove the cylinder head?, or can i just remove the head bolts and pull the head off? thanks
Old Aug 11, 2005 | 07:49 PM
O RLY's Avatar
Default Re: sohc head removal question (CivicFerioViRs)
Yeah, just remove the head bolts and the intake manifold bolts. It will come off the block easy as pie. However you may need to use a torque bar for leverage if the head was too tight, but that shouldn't be an issue.
Old Aug 11, 2005 | 07:53 PM
98b18black's Avatar
Default Re: sohc head removal question (rfoster03)
Yea...Just undo the head bolts and the manifolds and you're set...
Old Aug 11, 2005 | 07:55 PM
Copy Cat's Avatar
Default Re: sohc head removal question (98b18black)
awesome guys, thanks
Gunmetal_B20_Hatch
Oct 23, 2010 07:50 PM
LSEGHATCH
Nov 15, 2006 12:13 PM
JdM_RACeR07
Oct 19, 2006 12:43 PM
Firestarter
Nov 5, 2005 01:30 PM
jizzer671
Jun 8, 2005 03:40 AM
