'98 Civic EX: Headlight Replacement Installation Help
My '98 Civic EX needs new headlights but I am unaware of what exactly to do in order to change them. They have already been removed, so all I need to do now is install the new ones I bought. I heard that headlights on Honda's are pretty complicated to replace, so if anyone knows any how-to sites or DIY manuals online, I would be greatly appreciative. Thanks a bunch.
If there like mine all you do is put the housing in place, line up the brackets to the frame and put in some bolts to hold them in place about 3-4 per side. Then adjust them as need be to sit flush or adjust the beam as needed.
If your referring to the bulb its even easier, put the bulb in place being careful not to touch the lens, put the metal spring contraption in place that holds and locks it in, put the rubber boot back on and connect the wiring.
Thank you so much, I greatly appreciate it.
I was also wondering if you might happen to know where I could find some wiring diagrams for the headlight assembly? I'm not quite familiar with the Honda wiring for headlights, so if I had a diagram it would help a whole bunch.
Thanks again.
Thanks again.
loki2323
Jun 6, 2022 01:35 PM
=honda4life=
Apr 17, 2008 03:55 PM
98silverhonda
Mar 27, 2006 07:52 PM
civic_coupe
Jun 25, 2004 10:25 PM
