squeaking coming from the engine bay.....question
Old Feb 21, 2002 | 07:22 PM
hobo79's Avatar
New User
Default squeaking coming from the engine bay.....question
sqeaking noise coming from the engine bay of my civic, i think its coming from either the timing belt or the other pulley belts. they are stock, can i use some WD40 and oil it up to get it not sqeaking? if not, then wut should i do? the car has 61K on it. let me know. THANKS!
Old Feb 21, 2002 | 07:38 PM
rainforest's Avatar
Default Re: squeaking coming from the engine bay.....question (hobo79)
well if its tahts you can get belt dressing for it. it stops the sweaks from the belts.
Old Feb 21, 2002 | 08:06 PM
hobo79's Avatar
New User
Default Re: squeaking coming from the engine bay.....question (rainforest)
so then i cant just spray some WD40 on it?
Old Feb 21, 2002 | 11:08 PM
hobo79's Avatar
New User
also, when i put it in reverse, it squeaks too, which is alot louder. its a civic manual tranny.
Old Feb 21, 2002 | 11:20 PM
-=TWITCH=-'s Avatar
dont use wd40 bad!! its not good on belts it has a chemical that actually breaks down rubber and thats not a good idea to spray it around/near your rubber belts, go to a auto store and ask for some belt spray that will fix your prob. if it still happens check pulleys bearings etc!
Old Feb 22, 2002 | 07:30 AM
REDBARON's Avatar
Default Re: squeaking coming from the engine bay.....question (-=TWITCH=-)
You may also want to check that the belt is tight. Too much play will cause it to squeal at low RMP's.
Old Feb 22, 2002 | 12:08 PM
hobo79's Avatar
New User
Default Re: squeaking coming from the engine bay.....question (VTECHatch)
how do i know if it is tight enough? i am going to get the belt oil, or whatever its called and do that first. i can hear the squeaks a lil when the car is on, and when going forward, a lil as well and ALOT when i reverse. at first i thought that it was the dust disc cover for my rotor, but now i hear it more prominent in the engine bay. The car has 61K on it. when am i suppose to change my timing belt and other belts? if i buy the aem cam gear and pullys and change my belts, will this help it?
Old Feb 22, 2002 | 03:40 PM
fixhondas's Avatar
It could be the A/C idler pulley, compressor clutch, alternator, P/S pump, or belts. Take a long screwdriver- hold it to your ear and press the tip to different areas until you find where the noise is coming from. You can spray the belts a little to see if they are making the noise- if they are- replace them with HONDA drive belts. Belt dressing is for **** salads!!
supermeister
May 25, 2009 03:09 PM
NikeSB
Sep 14, 2006 04:23 PM
DW
Jun 29, 2004 01:55 PM
_Endless_
Nov 7, 2003 03:38 AM
$300lude
Dec 15, 2002 09:25 PM
